- Joined
- Aug 2, 2018
- Posts
- 10,352
- Reaction score
- 15,008
Thanks KB. Much appreciated.
Hi Folks,
I want to verify where one measures to determine if the truck is level. I believe that an earlier comment in this thread said that the measurement is taken from the ground to the underside of outside fender over the tire, and the measurement is taken vertically, with the measurement line passing through the center of the wheel hub.
Is this correct?
I am starting to think about larger tires and any associated lift/leveling to accomplish this on my 2007 Yukon XL Denali, and I want to make sure that I start to learn to proper terms and measurement starting points.
Thanks in advance.
You can level it by actual measurement or by sight. Some say that when leveled by measurement, the rear looks like it's sagging because of the body and/or rear window lines. It's up to you and your particular strain of OCD that determines what you would call "level".
Don’t be surprised when you get them. Measurment of the block will screw with your ocd....Yup. And this is why I’m going with 1.5” rather then 2” lift at front, as my strong visual OCD would perceive the ass end as sagging. Can’t have that for even an instant.
No sir! After that would come stretched low-profile mud tires, snot green Monster stickers, flat-billed hats, sleeveless shirts, white Oakleys and Drake blasting with the windows down at every red light.
