Leo1103
I've noticed a lot of those around where I live and most of them the daytime running lamp/strip go out.
I've heard they burn out as well, I was more or less going to switch out everything on these now so I dont have to ever go back and fix it.
Regency
Decided to pick up some goodies! Also picked up an android head unit.
M3kanic
Are you going to put a bypass on with the trucool?
M3kanic
I live in Virginia and I didn't put a bypass on mine and my temps are normally 135 unless I'm towing then they are around 160.
I'm in Cali and my Denali was always 180-205 (not towing) after I added the true-cool and a B&M deep pan it runs around 130-135, I was looking at this chart and figured i'm pretty good to go now.
Derick
Indy Suburbs
Took the burb to one of the trusted motor rebuild shops around here. The owner thinks its the main bearing. So, with them, options are 42-4500 to rebuild, or 6200 for a re-manufactured motor. :(
Going to stop by my mechanic and see how much he would charge to put in a new motor that I would have delivered. Found an LY6 on lowmileageparts.com for 3k. They have a decent warranty, but outside of that I'm not sure of their rep. If I choose to go that route, I'll just drive it till either it blows, or until the motor comes in stock.
M3kanic
https://www.facebook.com/marketplace/item/268029760556786/
M3kanic
Tbss comes with 6.0. They are fun. Think of that engine like a lq4/lq9.
randeez
south florida
drove it, and broke it.
started running rough while out running some errands. made it over to my buddys shop was smoking pretty bad out the tail pipe, lots of fuel smell. no check engine light but cyl #3 colder than the rest so we started there. pulled the plug checked spark, turned it over without the plug and whole bunch of full came out of the hole, injector seems to be stuck wide open couldnt find one local so wont be here till tomorow. scoped the cylinder doesnt look all that great but going to swap injector and see what happens.
had set up to get realigned and rear pinion seal swapped tomorrow dunno if im going to have to put that off now
This is what you need.
https://www.lowmileageparts.com/200...-2500-PICKUP-Engine-P315362.aspx#.XCVuQclOm7M
Derick
Indy Suburbs
BourbonNcigars
Drove around in a rain storm, trying to locate the source of water in my driver's side floorboard. I've scoured the webz (seems a common problem) and still can't find where it's leaking. Damn it.
kbuskill
NE. FL.
Bwaldron
