I've heard they burn out as well, I was more or less going to switch out everything on these now so I dont have to ever go back and fix it.I've noticed a lot of those around where I live and most of them the daytime running lamp/strip go out.
Not sure. Was going to have my shop put it onAre you going to put a bypass on with the trucool?
Drove it 750 miles from Detroit to Greenville, SC... Preformed flawlessly, averaged about 18 mpg.
Sent from my Galaxy Note9 using Tapatalk
It sure is. I'm actually in Greer off highway 101 (so just an exit away!).Right up the road from me in Duncan, SC. Small world.
https://www.facebook.com/marketplace/item/268029760556786/Took the burb to one of the trusted motor rebuild shops around here. The owner thinks its the main bearing. So, with them, options are 42-4500 to rebuild, or 6200 for a re-manufactured motor.
Going to stop by my mechanic and see how much he would charge to put in a new motor that I would have delivered. Found an LY6 on lowmileageparts.com for 3k. They have a decent warranty, but outside of that I'm not sure of their rep. If I choose to go that route, I'll just drive it till either it blows, or until the motor comes in stock.
Lol I work in DuncanRight up the road from me in Duncan, SC. Small world.
This is what you need.Took the burb to one of the trusted motor rebuild shops around here. The owner thinks its the main bearing. So, with them, options are 42-4500 to rebuild, or 6200 for a re-manufactured motor.
You got an XM sharkfin antenna?Drove around in a rain storm, trying to locate the source of water in my driver's side floorboard. I've scoured the webz (seems a common problem) and still can't find where it's leaking. Damn it.
You're goddamn right I do. I asked my mechanic about retro fitting an 8.1 into it awhile back...he said it probably wasnt a good idea. Not to mention the stuff from that site is bare bones...I'm sure I'd need all the computers too...
Nope. My hole lies elsewhere.You got an XM sharkfin antenna?
