Tire wear with djm uca,lca
Lit549
So I'm about a 7 months into lowering my 05 tahoe with Djm uca and lower control arms.I've started noticing wear on inside tread of tires,they're starting to feather.I had the front end aligned ,it's actually diving a little free every since doesn't rod walk bad but isn't tight either.All bushings and ball joints are in good shape.Wheels bearings have a little play when prying on bottom of tire while jacked up.I've noticed ,after the uca install,the tire and wheel looks to have a bad caster setting,it physically doesn't look right .Any suggestions?These tires aren't very old,who knows of a front end alignment shop that does lowered vehicles around dallas,ft worth,waco??
Lit549
Lit549
It isn't even that low either,it's a 3-4
rddixon
