With temps below 70 early last evening, I finally had a chance to repair my rear window defogger tab. Around the time of the last winter cold snap, the tab fell off the heating element so I bought the Permatex 21351 kit. Upon reading the instructions it said not use when temperatures were above 73 or something. So I shelved the project until now, took all of 5 minutes and now it's been curing and will test it out tonight.
GranPrix
Let us know how it goes. Mine also broke off but I'm further south so I might be waiting a bit longer than you.
Ilikemtb999
Denver
Changed the oil last night and found my trans cooler lines are leaking but wasn’t sure where. Hosed it all off and will wait and see. Also after looking at pictures of new ones it looks like the feds decided to “fix” one already.
Hi-psi
Atlanta, GA
A while back I installed a Fumoto valve to make oil changes easier/cleaner.
I'm still trying to come up with a solution for the oil filter removal, which can be a bit messy. So far the best method is using a nail to punch a hole in the lowest point of the filter and then let it drain first. This works, but still requires a drain pan or a funnel and jug.
I'd love to find some type of self piercing/tapping drain valve that you could attach a rubber line to.
I found a product like this for aircraft engine oil filters that looks like it would work, but the price ($40) is a bit more than I'd like to drop on such a luxury. Anyone have any ideas?
I found this one that is cheaper, but it doesn't look like the company is still around.
Also found this video, which really to me is the best approach, a strong magnet, stick to the bottom of the filter, tap with a hammer to pierce, open the valve. But, doesn't look like the guy is still around or making them.
Ilikemtb999
Denver
Interesting, I just use a wrench to loosen it and then spin it enough till it pours out and let it sit. Still gets messy. I forgot to order a fumoto valve. I’ll have to get on it before my next change. Had one on my Subaru and it was amazing.
Hi-psi
Atlanta, GA
Let me say, I'm not some prissy missy that is worried about getting dirty. LOL However, I live in an apartment complex that is extremely strict on a no vehicle maintenance policy. So, what I usually do is drive a couple miles up the road to the Advance Auto and do my oil changes in the parking lot there. If I could come up with a cleaner way of addressing the oil filter, then I wouldn't have to lug my oil drain pan with me when I do it. Just a couple of empty oil jugs.
gpracer1
Phoenix
It seems they used fluid filled motor mounts for a reason.
I can now totally feel the engine idle like it a bit "rougher", after installing driver side Hummer mount.
this is for freon cans but no logical reason you couldn't just attach some rubber hose to the fitting and use it for oil
https://www.ebay.com/itm/Refrigeran...=item35c8c19a5a:g:GHUAAOSwstxVRhaS:rk:20:pf:0
Hi-psi
Atlanta, GA
Yeah, I actually considered that...but I don't think it would work. Those are usually smaller diameter, designed for refrigerant cans that are about the size of a coke can. Plus with the thickness of them, wouldn't be able to get around the oil filter in a lot of applications.
Really need something like that Youtube video that would attach to the bottom of the filter.
theres always the option to just outline what you want in a drawing and give it to a machine shop, those guys can make anything, probably be more than $40 though, if you have a drill press and a grinder you could make one
I crack my filter loose, not enough to leak, then put doubled-up plastic grocery bags over it and spin it off by grabbing it through the bags. It falls into the bags and I tie it up and throw it away- no drips or leaks. I change oil in my cars without getting a single drop on the floor and barely anything on my hands and I have plenty of Walmart bags at all times.
Meh. It's only at idle and I'd rather feel that than the clunk of a broken mount and the pain of having to replace the mount(s) more than once in the vehcle's lifetime.
gpracer1
Phoenix
Yes, and after the first time Im sure it would only take 30 min to do it again. I cant imagine how long the OEM one lasts if towing over 5000 lbs.
M3kanic
Knock on wood. I tow a 6500 lb camper and have 152k on mine and still have the OEM engine mounts.
It has the hydraulic ones? No orange/rust colored residues on or around the mounts?
M3kanic
I have a 2010 Denali if that makes a difference. But the last time I checked they clean.
Definitely should have the hydraulic ones if they're original. And this would be quite an accomplishment, indicating easy driving and very easy accelerating when towing. Regardless of the stresses induced on the mounts, you'd think that the sheer age of the rubber would overcome all that easy driving and it'd crack and leak anyway. Maybe you live in an environment better suited for the livelihood of rubber? In my area, quality windshield wipers are dry and streaky after about 6 months and may last a year if you park in a garage.
CliffB
