Tahoe Duraflex ZL1 hood
BeenChevy
Minnesota
The Bermuda blue is due for paint touch up and dent repair and now i'm thinking of swapping the hood all together.
Anyone in here have experience with Duraflex hoods? I see there are likely defects and flaws with them. I want a better understanding of what i'm up against or if these are just garbage.
05Single
afraid of the dark
I've never seen an aftermarket hood that didnt need work to fit properly. For our trucks or any other cars or trucks. You will need to put in some tlc to get that perfect fitment, and in some cases perfection is not achievable.
That's my heads up for you.
Same goes with aftermarket grilles and bumper covers. The struggle is real lol
massivespl
I'm not mean, I'm honest.
Michigan
My buddy got one for his 2011 and it needs work. Needed to cut the truck by the latch to make it close right. Needs lots of sanding and bonds to make it look show quality. Looks good from a few feet away though
BeenChevy
BeenChevy
Minnesota
Good to know. My alternate thought is an OEM HD hood - These can be expected to bolt on with no modification?
massivespl
Michigan
I was looking at steel cowl hoods from jeggs. But that was for my 2011. Idk if they have steel ones for 99-06
05Single
afraid of the dark
It will still be aftermarket and might need slight adjustment. But for the most part the oem style usually fit really good from what I've heard. But I've never personally had experience with those. Usually people go on a search party for months to find the nearest one from a salvage yard. Usually they are true oem so fitment is perfect.
Thouse
Looks surprisingly good. I had no idea I would like it so much.
chevrol8t
I was curious about this hood as well. I've seen it on carid.com my only issue is that they suggest hood pins to keep the hood secured? I would like to get this hood as well for my `00 Tahoe but I want it to retain the factory latches and hinges. If you get this hood and that is the case (or not) can you please update?
curbud
