Smoother Denali ride??
donn
Xineering.com offers a kit that includes shock and ride height simulators that will make the computer think the Mag Ride parts are still installed. The kit for front and rear is $425.00 and includes four ride height simulators and four shock simulators. Replace with quality shocks and enjoy the ride. I replaced all four shocks with AC Delco standard in the front and AC Delco air shocks on the rear.
mpgmc
I took my '18 xl denali in today for its first service and reported the issue to my SA. Will see if they come back with anything. I'm running 35 psi cold. I know it's a different car, but the loaner Acadia they gave me has a much better ride. I hope they can fix it. I might need to try different tires too...
O
OilfieldTrash78
My 2015i Yukon SLT road a lot better on the tougher roads. Now the Denali rides great on the highway, but every single bump is felt
Bryingram4
San Diego CA
A quality tire makes a big difference. I have 24’s wrapped in 285/35 Pirelli Scorpion Zero’s. The Mag Ride is flawed by design in my opinion. But my new set up is still smoother than the oem 22” denali wheels on whatever the factory puts on them, I forgot.
My big quedtion is, does AC Delco have an airshock to replace the rear MagRide airshock? And what is the part number? It should be the same for 2015-2019
Bryingram4
San Diego CA
So just to be clear, the air shocks in the rear are for the auto leveling system?? Did the air lines just plug right in? And of course the Xineering plugs need to be used. And you did this on your 2015-2019 Yukon Denali? Any information is greatly appreciated. Thank you
Dearmosd
any update on what the service did for your ride quality?
Dearmosd
bradntx
I'm glad I'm not the only one who thinks the ride is a bit harsh for what is supposed to be a luxury vehicle. From the beginning I wasn't quite sure about the harshness and whether my truck was normal. Today I drove 350+ miles with the truck pretty well loaded with stuff and it was night and day from the ride with just me in the truck. I think these things are sprung so that they ride good with 4+ decent sized adults in them and when totally unloaded the ride is harsh. I don't think it's the shocks but the springs. When you load them down a bit everything is much more compliant. I have been contemplating a 2/4 leveling drop and want to find out about the spring rates on the rear lowering springs.
I was actually considering removing the rear seats and shelf permanently but am not wondering if that would make it even worse.
Dearmosd
i will have to say I just had the mechanic adjust my ride level sensors and WOW an extreme difference in rear ride quality in my opinion. He said he adjusted the angle pinion of the bracket which increased the length tricking the computer to think it was higher then needed allowing to release some air in the bag that level the rear.
Whatever he did made a complete 180 on the rear end. It was extremely stiff in my opinion and now I can feel it bounce over bumps which I never felt before.
I would have to suggest to extend the sensor rode length and try to trick the computer to think it is above the stock height and see if you achieve a softer ride.
That's what I've been trying to tell you guys! LOL
bradntx
I just went back through the thread and saw your post. I have to agree with the high GVW and high towing capacity they have to have some significant springs in the back. Unloaded they are going to ride rougher. These trucks as what is classified as a 1/2 ton has the capacity of a 3/4 ton of 10 or so years ago. Crawl underneath and look at the frame then call under a 10 year old half ton truck and compare. These things are seriously beefy in the frame. Anyone comparing to them to a mid sized cross over is going to be seriously disappointed due to just about all mid sized crossovers having 4 wheel independent suspensions these days. Those same vehicles however don't have an 8500lb towing capacity.
Dearmosd
so would simply a different spring help the ride quality. Now I also question is the MRC reacting more than it needs to with minimal bounce either from the tire or spring?
Drewphil
