Installed wireless charging into the center console lid
Kenneyd
NE FL
We use our Yukon for a lot of trips, and undoubtedly, we forget our charger from time to time. I know a lot of newer cars have the wireless charging in them, but I've always wanted it in the Yukon.
Last weekend I took apart a standard wireless charging pad to see how it worked, and experimented with the distance it would charge at.
Unfortunately, it turned out that mounting it beneath the plastic center console tray, that plus the rubber insert, plus a case on the phone was just too much of a distance.
The only real option was to epoxy it in place just below the rubber insert. I've then stripped it down to make it only about 2-3mm thick, and then poured the resin I use for carbon fiber repair, (which is kind of like epoxy), over it.
I then drilled some holes for the rubber insert to stay in place and the screws to go back in the original slots.
I bench tested it, and everything worked great
I ran a standard USB cable inside the lid to the 5 volt source, behind the factor USB plug.
I then went to test it, and it did not work. Grrrr. It got power, but would not start charging. To troubleshoot, I then replaced it with another USB cable directly to a 2.4 amp plug, and everything worked fine. So it turns out the factory 5 volt is a very low amp plug.
I purchased a 12 volt to 5 volt/ 3 amp stepdown convertor from Amazon and wired it to a switch 12 volt source, and everything works awesome!
It's very convenient, and we use it all the time. I've thought about painting it flat black, but I actually kind of like seeing the coils when I lift up the piece of rubber.
Testing below the plastic tray
Submerging in carbon fiber resin
Installed without rubber insert
Installed with rubber
RST Dana
OH
Great work
NebraskaJ
Where did you tie into a switched 12V? I'm getting ready to start the exact same project, plus I'm adding in a Bluetooth module and I want both of them to have power only with the key on.
Kenneyd
Kenneyd
NE FL
I'll let you know this weekend, I got ahead of myself with the post.
I actually wasn't able to finish the 12-volt,. Most of the 12 volts around the glove box area are on all the time. I assume I'm going to have to go back to the fuse block if I can't find one
GranPrix
Nice! You might be able to make a profit here for the folks that aren't able to tackle this project if you're willing to make a couple of these... ;)
Kenneyd
Kenneyd
NE FL
Kenneyd
Kenneyd
NE FL
How difficult/expensive is the resin?
It was very easy.
I actually dont know the brand of the actual product i used, but it seems very similar to 3m fiberglass resin, Just crystal clear instead. I got it from a carbon fiber shop to repair some car parts and he poured in into a non marked jug
Anyway:
-seal up the holes
-tape off the pretty parts of the lid to protect from drips.
-I set the whole thing on a bed of play dough on the counter top so it wouldn't move and was level
-mix up about 4 oz of resin, a few drops of hardener
-Pour in until it just covers the top of the coils
-Use a head gun if needed to get the air bubbles out
-After about 10 min its very firm, and i just drilled out the holes for the screws and the rubber insert piece.
-rock hard in about 20 mins
I did have to un solder the coils from the circuit board, which i attached to the bottom and then re solder the wires on.
GranPrix
I might just do this myself. I didn't realize how cheap the charger was. Do you have anymore pics of how you ran the wires?
scottd
