95escahoe
- Joined
- Aug 2, 2010
- Posts
- 5,162
- Reaction score
- 4,466
Get any footwell lights?
I thought about it but don’t really need them the interior LED’s are so darn bright
PowerTrainProducts
Not familiar with the case saver bit
I hate those clamps. I’m thinking I want to look for spring clamps like factory to use on my trans cooler, or go with AN fittings. I bought the special spring clamp pliers awhile back which make removing/ installing them easy.So....installed a new steering cooler and as another member said, watch those cheap clamps that come with it. It was leaking at the cooler to rubber line connection. I found out that when I checked it with a screwdriver it was bound up on the screw drive of the clamp just before it was really tight. Very small leak. Had to use a ratchet and got it to tighten up. No more issues but I did have to take the grill and headlight out again to find and fix it.
View attachment 210436 View attachment 210437
Front differential, not transfer caseCase saver is a thing that keeps the pump from rubbing its way through the case as has been commonly noted as a known issue.
Make sure you get your alignment checked too. It takes surprisingly little to tweak the stuff outI was rear ended today, 40mph by a dodge ram. Happy I kept my bumper and tow hitch instead of run a rollpan, for this exact reason.
Small dent on lower rear quarter from the bumper. May take it for estimates and pocket the cash. Fix the bumper brackets and call it a day
That's definitely on my list, felt the truck pulling to one side afterwardsMake sure you get your alignment checked too. It takes surprisingly little to tweak the stuff out![]()
Where’d you get the clear housings? Decent quality?I got a set of smoked headlights last year with a set of HIDs i guess they would get way too hot that started to fry the lenses so i got a new set of housings hopefully i dont have that problem with LED
View attachment 210492 View attachment 210493 View attachment 210495 View attachment 210496
PowerTrainProducts
Oh yeah.![]()
Picked up the glove box light and wiring along with the wiring for the rear door lights off an 02 since my 04 Esky has neither
My 3rd row has dome light for the back area. My 04 hoe has barn doors- were there lights in some of the barn doors?
After I think 02 they got rid of the glove box light and the lights in the rear doors, not the barn or rear doors the door behind the passenger and driver
My 03 has the glove box light, so 03 was the last year for that. 02 was the last year for the footwell lights also.After I think 02 they got rid of the glove box light and the lights in the rear doors, not the barn or rear doors the door behind the passenger and driver
Did you check the pins in the blower motor wire connector? I've heard of corroded or burnt pins there. It could be the control too; just because it lights up doesn't mean anything. Ebay has used ones for pretty cheap usually.Hey guys I need a hand. My front ac/heat stopped working. The control unit works (well display lights up and what not but the blower wont kick on.
I've replaced the resistor a couple months ago. But today I tried a new resistor as well as a new blower motor.
The fuse is good and all wire connections are solid. I'm at a complete loss right now. And winter is coming which means I need my defroster
Yes my 04 does not have a glove box light. Is the provision still there to mount one or are you going to have to rig it up?
