So....installed a new steering cooler and as another member said, watch those cheap clamps that come with it. It was leaking at the cooler to rubber line connection. I found out that when I checked it with a screwdriver it was bound up on the screw drive of the clamp just before it was really tight. Very small leak. Had to use a ratchet and got it to tighten up. No more issues but I did have to take the grill and headlight out again to find and fix it.
View attachment 210436 View attachment 210437
I hate those clamps. I’m thinking I want to look for spring clamps like factory to use on my trans cooler, or go with AN fittings. I bought the special spring clamp pliers awhile back which make removing/ installing them easy.
inmypassatlife
I was rear ended today, 40mph by a dodge ram. Happy I kept my bumper and tow hitch instead of run a rollpan, for this exact reason.
Small dent on lower rear quarter from the bumper. May take it for estimates and pocket the cash. Fix the bumper brackets and call it a day
SnowDrifter
Sasquatch Country
Make sure you get your alignment checked too. It takes surprisingly little to tweak the stuff out :)
00chevyHd
I got a set of smoked headlights last year with a set of HIDs i guess they would get way too hot that started to fry the lenses so i got a new set of housings hopefully i dont have that problem with LED
20181107_070845.jpg 20181106_180626.jpg 20181103_174204.jpg 20181107_070958.jpg
eand28
Pennsylvania
Thouse
Picked up the glove box light and wiring along with the wiring for the rear door lights off an 02 since my 04 Esky has neither
My 3rd row has dome light for the back area. My 04 hoe has barn doors- were there lights in some of the barn doors?
95escahoe
After I think 02 they got rid of the glove box light and the lights in the rear doors, not the barn or rear doors the door behind the passenger and driver
Thouse
Yes my 04 does not have a glove box light. Is the provision still there to mount one or are you going to have to rig it up?
My 03 has the glove box light, so 03 was the last year for that. 02 was the last year for the footwell lights also.
petethepug
Michael
SoCal
My buddy was just rear ended by a Dodge Promaster cargo van in his 14 6.6 Silverado Duramax. The tow hitch disembowelled the cargo vans front end. Slightly bent the trucks rear bumper.
I’m not a fan of walking into tow hitches left connected on vehicle bumpers. I certainly do enjoy kooks driving beyond their limits and encountering the same hitch on a HD vehicle. It really helps the tailgaters rethink their driving habits through their pocket book.
Bombsquad85
Northern VA
Hey guys I need a hand. My front ac/heat stopped working. The control unit works (well display lights up and what not but the blower wont kick on.
I've replaced the resistor a couple months ago. But today I tried a new resistor as well as a new blower motor.
The fuse is good and all wire connections are solid. I'm at a complete loss right now. And winter is coming which means I need my defroster
Did you check the pins in the blower motor wire connector? I've heard of corroded or burnt pins there. It could be the control too; just because it lights up doesn't mean anything. Ebay has used ones for pretty cheap usually.
95escahoe
I’m pretty sure it was ran off a wire that was already there, I’ll findout when I wire it in tho
wwiizz
