Performance air intake?
Blueinterceptor
chevy is offering a performance air intake cleaner as an option.
What does this do? Cost is not specified.
It’s not the high capacity air filter that comes on the rst
Mad Maxx
Long Island, NY
It voids your warranty just as any aftermarket one does, doesn't make as much power as aftermarket, and costs a shit ton more than aftermarket.
B
Blueinterceptor
It’s a Chevy part that’s offered as an option in the ordering guide the same as tow hooks are. So it won’t void your warranty.
WillCO
Castle Rock, Colorado
It won't unless it will, and at the point you find out one way or the other it will be you and your resources against General Motors and theirs. Considering that these don't add anything other than noise, I pass. To each his own.
B
Blueinterceptor
Thanks. You answered my question. Adds noise.
Jbsailor
It won’t void your warranty unless it can be proven that this mod caused whatever problem you encounter. If you sucked in a ton of sand and screwed the cylinder up, it could be so. If your tranny breaks, it’s highly unlikely it could be found to be the fault.
drakon543
as much as a rip off as most stealerships are if you replace the valve stem caps on your tires with nice shiney ones they are likely to try and void your warranty. its mainly the people who keep thier mouth shut when a dealership trys to give them the shaft over warranty work. if its a certified gm part and you have it installed by the gm shop there should be no issues with warranty. also yes the biggest benefit everyone tends to like about performance intakes is the extra growl you get from your engine. generally an intake alone wont get you enough power to matter. if your looking for a single item with noticeable gains just get a tune. if you want more after that a typical handheld tuner can revamp your tune with a second tune version or stage to accommodate an actual intake getting you better gains from and intake and possibly other mods. however a tune will definitely generally void your warranty. so keep that in mind for the future when your warranty starts to expire.
B
Blueinterceptor
I’m still unsure how the intake can void the warranty. This is a gm (Chevrolet) option from their ordering guide. It’s a new FACTORY option. You can add it like you add factory navigation or an rst package during the build of the car
drakon543
about the only way a factory dealership installed option would void your warranty is if you bought it and installed it yourself. they could come back with you must have installed it wrong. doing your own oil changes or having a non gm garage do them can "void" your warranty. void your warranty isn't really the right word anyway think of it more like if they can tie any kind of failure to something that wasn't done by them. if you do your own oil changes and your engine fails they can come back with you were using the wrong oil or there is no record or proof you actually were doing the oil changes.
LT1ZOB
GM still has to sell it in, and comply with CA “CARB”. So you likely get a cute plastic window, a “performance” logo of some sort, but nothing else.
For performance options, you have to plan ahead of time and go aftermarket with items that will “play well together” (i.e. cold air, larger intake, headers, exhaust, 93octane tune, etc). Otherwise, you’re simply opting for a useless kick in the balls. Aftermarket has the advantage of “off-road” use or flat out refusing to sell in CA. They don’t have to worry about selling a mass produced car everywhere.
I’ve lightly modded both my Camaro LS3 and vette LT1. One item such as a cold air intake doesn’t do much without other components. On my Tahoe, all I did was drop in a K&N filter. Not because it does anything other than allow me to hose it off and reuse it. So just for convenience really.
WillCO
+1. The word "void" implies that they would cancel your warranty. Doubtful. They more likely would refuse to cover a certain problem under the warranty if they think your acts or omissions acted against the warranty's terms in that instance, but leave future coverage decisions up to the circumstances surrounding those decisions.
It's all there in the fine print. We all signed it and none of us read it.
Like I said before though, if you end up at odds with a car manufacturer over a denied warranty claim, you fight against a much better equipped opponent who is trained and prepared for the fight, whereas you are not. It would cost you orders of magnitude more to defeat a denied warranty claim instance than it would to pay for the repair yourself.
My conclusion has been to wait for the warranty to expire before I consider any kind of performance enhancing modification. That time comes around before you know it, and at that point the whole warranty risk goes away.
Mad Maxx
Long Island, NY
While I agree with what is said here from others, the GM intake WILL in fact void your warranty.
I forget exactly where I read it (trying to find it), but the question came up about the GM Performance Intake, and yes, while being a GM Part, ultimately, it is still considered "tampering" with the Intake System, and having the Engine operate outside of its designed use, and should any problems arise, where the Intake was the cause, it will not be covered.
RST Dana
OH
I have had a similar conversation with my service manager and was told I would not have any issues with my warranty at his location. He liked the look of my Volant too. I have a lifetime power train warranty on my ride from this dealer as well.
WillCO
Warranty coverage decisions don't come from the service manager at a dealership; they come from a dispassionate analyst sitting in a cubicle somewhere else.
Rich16LTZ
They don't "only make noise". Dyno results have proven time and again that there are HP/Torque gains attained from adding a good (Volant, S&B, AFE) CAI. Maybe only 15-25 hp, but it's something. Adding aftermarket exhaust system or even a better muffler will add to that as well. After that, add a tune and you'll have noticeable gains. I had a proven 2-3 mpg (highway) gain on my 2015 Silverado 6.2, not as much on my 2016 Tahoe. Also, I've never heard of a single owner's warranty being voided for CAI, that said, an aftermarket tune will more often than not void a powertrain warranty.
WillCO
Generally proven only by the companies selling them. I looked a long time for objective data on both exhaust and intake mods and never found any that pointed to performance gains. Maybe you had more luck.
If increasing performance was as simple as adding a less restrictive intake, and if doing that wouldn't compromise longevity, reliability, or something else, why wouldn't the car manufacturers be doing it?
Rich16LTZ
There's dozens of things they can "do better" but choose not to, this is one of them.
WillCO
Nah. As hyper-competitive as the domestic truck market is, these companies will do absolutely anything they can do to gain an edge. There are smart people who spend all day every day trying to identify advantages.
dbbd1
I am on the fence about CAI's. But, I do feel less restrictive anything is usually better.
The reasons that manufacturers don't do these things are most likely because of federal regulations (specifically emissions). That is also why a simple tuner will open up some more power. They may push to the edge but, cannot cross, an invisible line of power vs mileage vs regulations.
Drewphil
