Useless Information
Ok James... school me...
What is the purpose of a lower thermostat with a lower viscosity oil???
I have considered changing to a 0w20 or 0w30 oil as well and never gave a thought to changing the thermostat.
A 0w30, at operating temperature, would effectively be no different than the 5w30, at operating temperature, we are running now.
Also would we need to account for the thermostat change in the tune?
Would the ECU ever get out of open loop if it didn't "see" the engine was up to temperature?
Well Ken, I think the lower temperature combined with the 0W20 oil would allow the lighter oil to have a higher shear resistance, the ASTM D4683 standard. Many 0W20s are 2.7-2.9 while the 5W30s are 3.0-3.3 @ 302 degrees.
There's a lot for me to learn on this, my eyeballs are hurting from gathering all the oil specs and trying to learn what they mean!
I do not think it wise to lower the temperature to 160 like I did in the old days. As one of my racing mentor's used to tell me, "Heat Makes Horsepower". But if we lowered our engine temp about 7-10 degrees, that would keep the engine oil to around 212 at high speed and lower the trans a little more and the ECT too of course.
The tune could be changed to take advantage, especially the fan kick on speed lowered a corresponding amount.
Yes, too cold would be a problem and cause the motor to run rich and get worse mileage.
I've been following Grumpy Bear's posts over at GM-Trucks and how he has an average mpg of nearly 30 mpg with his V6 full size pickup. He's doing things along the lines as I used to years ago.
Just thinking of ways to tweak the mpgs and still have the cake.
Do you have any new highway mileage numbers on yours?
kbuskill
NE. FL.
Haven't really been anywhere lately... Been to busy running around to Dr's and physical therapists and surgeons.
Aerodynamics play a role in the non-linear MPG curve. I'm sure you already know that the coefficient of drag increases in a square to the velocity. So, as speed increases, the drag does exponentially. What I suspect causes the "dip" in the curve may be areas of high and low pressures forming at various speeds which essentially alter the way the higher-velocity air flows over the vehicle, as if the vehicle changed it's shape. This is much how leaving a tailgate up versus down actually creates less drag because, at highway speeds, the bed fills with high pressure air which lets the higher-velocity air (lower pressure) skim over it like a bed cover. This effect varies with speed. So, my thoughts are that maybe at lower speeds, there isn't/aren't a pocket(s) of air so the hard shape of the vehicle determines the drag. Then, at higher speeds, a pocket/some pockets develop, reducing drag enough to overcompensate for the extra fuel consumed by the increased engine RPM. Then, at even higher speeds, the fuel needed balances and then overcomes even that drag efficiency.
I reckon that's so but figured it would be more linear as speed increases. In addition, the truck on E85 dropped .8 mpg from 65 to 70 and .5 from 70 to 75. MPG were essentially the same at 60 and 65 mph. Now that E85 made more horsepower so it was able to maintain speed with less drop in mileage as the resistance increased. Now I need a wind tunnel to test this thing!
On the other hand, the mileage ratings seem to fall in line with those trucks with 3.08 gears. At 70 mph they're turning about 1500 rpms with 3.08 gears. Mine will turn about 1500 rpms at 65 mph. And if you were to turn 1500 rpms in top gear, that would be 54 mph! Does being shorter and lighter make that much difference? Not according to GMs fuel economy ratings for these trucks but real world should be different. I guess I could take a look at Fuelly and see what the short and long trucks are averaging.
Ok, just got back from a trip to Fuelly and my trusty Excel spreadsheet.
The purpose of this post is to see averages of the types. These are the averages of the mileage that people post, so it is a combined city/highway rating.
5.3 Flex Fuel engines were chosen. 2007-2014. Tahoe, Yukon, Avalanche, Suburban, Yukon XL
There are many ways to figure averages and I did them. By year, model and short or long and by features.
So here's an example:
For the Tahoe/Yukon:
2007-2008 = 14.38 MPG (4-Speed Transmissions and Single Pattern Camshafts)
2009 = 14.65 MPG (6-Speed Transmissions and Single Pattern Camshafts)
2010-2014 = 14.54 MPG (6-Speed Transmissions and Dual Pattern Camshafts with VVT)
For the Avalanche/Suburban/Yukon XL
2007-2008 = 13.90 MPG (4-Speed Transmissions and Single Pattern Camshafts)
2009 = 14.00 (6-Speed Transmissions and Single Pattern Camshafts)
2010-2014 = 14.50 MPG (6-Speed Transmissions and Dual Pattern Camshafts with VVT)
The Average for all of the GMT900 SUVs is 14.37 MPG.
FuelEconomy.GOV lists the combined average for the 2007-2009 models as 16 MPG and for the 2010-2014 models as 17 MPG. Not!
So last night Justin sent over an updated tune. Not having done this before I pulled up the instructions and went out to the truck and installed them. I think. You see, I only turned the key to the accessory position and it ran through the paces and told me to turn the key off for 15 seconds. Did that. But later, I came back in and really read the instructions and I was supposed to have put the key to run and taken it out of the ignition when told. So I went back out and the AutoCal this time said to turn the key off, so I removed it, waited for the countdown and then did the TCM the same way too. When doing the TCM both times, all kinds of errors came up on the DIC, Traction Control, Trailer Brakes, etc. All went away when process completed.
After the first time, I took the truck out and averaged 18.2 @ 70 again five different points, from a low of 17.5 to a high of 18.9. I've read a lot about guys who put these engines in cars getting good mileage above 2000 rpms so later shifted it into M5 @ 70 for a long spell and she averaged 17.5.
So now I have to do it all over again. Was going to make a second run last night but the rains came and are still upon us.
Switching back to Mobil's gasoline, the alcohol content is down to 2% from 7-8% and that is sure to help mileage.
Next time out I'm thinking of pulling up on the Tech2 the engine load and torque to see why I get those differing numbers north and south on that part of the highway. I wish I had an inclination sensor, thought I'd seen one in the Tech2 before for the airbags but can't find it so the load % and torque should help give a better understanding.
Way back when AFM was new, guys with HP Tuners were tweaking it to run longer. They discovered that by manipulating the vacuum and TPS settings they could even accelerate slightly in V4 mode, even a guy with an Avalanche. I wonder if they're still around and driving these trucks 11 years later. Most of the posts are from 2007 and 2008, before everyone started turning it off. Some of these guys were getting mid 20s. One of the parameters for AFM to kick off is if the TPS hit 12%, well mine was cruising at 70 mph @ 30% so don't even know if it would kick on in stock form.
My TPS at idle is 8% again. When it cools down I'm going to finally put those breathers in and get that blowby out of my intake and TB.
kbuskill
NE. FL.
I think I finally got my ethanol % to read properly on the torque pro app. I thought I had the engine oil life monitor reading properly, but I was mistaken.
Just FYI... I don't know what BBP tells you about flashing things BUT Lew from Diablew custom tunes says that these trucks take approximately 100-150 miles for all your fuel trims to level out after flashing a new tune.
When you do the logs for him, and he sends you a new tune, he says to drive it 100-150 miles before taking a new log to send in for tweaks to let everything settle.
I only mention this because your freshly installed tune may not give you accurate/consistent results until after the mileage mentioned above.
Thanks Ken. No, Justin didn't give a length of time but asks for a datalog to be sent in to analyze the effectiveness of the changes. Most of the house got a bout of food poisoning so we didn't go anywhere today but the head and back to bed. If I read his email right, this particular update is focused on that 70 mph cruising speed. Have a short run coming up on Tuesday.
3 out of the last 4 tanks of fuel have averaged over 15 mpg (15.95, 15.12, 15.58). One of them averaged 10.81 mpg. That was the trip into the woods where the truck went swimmin'.
So the new tune is in, tank is filled up and waiting for cool weather and no traffic to do some tests.
Eye Doctor said the pain in my eyes and resulting headache is because of dry eyes and a bi-product of diabetes. They don't feel dry but will get whatever he scribbled down, can't read it. My wife usually can figure it out.
Usually you wouldn't be able to read it even if you had 20/20!
Well, it seems like Justin's updated tune has done good. Averaged 19.13 MPG @ 70 MPH yesterday. LTFTs heading south in the morning remained rock steady at 0%. Heading north in the afternoon they moved around a bit. Especially the right bank. 1% usually on the right but sometimes 1 and 2 for both sides. Temperature was about 1-2 degrees warmer and the ECT reflected that as well. When I could at the Tech2, the Engine Load heading south was between 61-65% and while heading north (different highway for part of run) it was 53-65%.
At one point I pulled behind a rig and was getting over 20 mpg! If it doesn't rain, I'll redo those 65-70-75 MPH runs and call this project finished. Oh but wait, Justin and I didn't talk about extending the AFM on time to see if there are any gains to be had there. Well, maybe I should count my blessings and leave well enough alone. What do you guys think?
HiHoeSilver
Away!
Chicago
Keep playing. This game is fun!
Ran through another tank of fuel which averaged 15.78 mpg of mixed city and highway driving. This is also the first full tank on the new tune that BlackBear sent. Save for the tank of fuel on that trip into the woods, the last 4 tanks of fuel have all averaged over 15 mpg.
I'm waiting to hear back from Justin about some questions sent his way and the AFM modified tune but think we're about done trying to maximize performance and efficiency now. I want to get the truck back on E85 and back to the drag strip when the weather cools off.
That noise under the hood keeps coming and going. Heard it tonight and by the time I ripped open the sthethascope from the package, it had stopped. Probably the power steering pump.
Did some two way averages as well tonight but the wind was blowing pretty good and the numbers are useless. There was about a 2 mpg difference between directions and there was spotty rain to boot. Took my wife to dinner instead.
I'd like to add 2 or three more GMT900s to our barn. A C/K10706 and a K10753, a short Yukon and an extended cab Sierra. Or give this one to my youngest and get a 2500 Suburban/Yukon XL for me.
Ohh, it's nice that the price of fuel has been steadily dropping. Prices have dropped $.24 cents a gallon since August. Paid $3.259 tonight. E85 is still bouncing between $2.45 and $2.49. I forgot, I think I was gonna run some 89 and 87 through the truck and see how that does. We'll see.
My lovely wife had the truck washed and detailed the other night to surprise us. The girls have been busy with school and they usually do most of the cleaning with/for me. Well, our youngest wasn't feeling so good this morning and stayed home. If she was up to it, a little Dad and Daughter time would be nice and I was thinking of scouting out a place called Plant Bamboo.
There are few G-Rated links from youtube to post about the place, hence why we went on a weekday!
Once I mentioned it, her stomach ache subsided rather quickly and we were off! The place is on the western end of beautiful and scenic Martin Highway, where oaks overhang the road and provide lots of shade. Couple of seconds and you get the idea:
We get to the place, sign in, fork over some cash and were off on our own with the run of the place. The workers were gearing up for the big event this weekend so pumps were going here and there to flood areas and make mud.
I purposely leave the tires at their regular inflation to see what she can do in 2WD. She does just fine but out back in the woods with only cows around I put it in 4HI to be ready for anything. There was a steep and short hill that we drove around, didn’t want to get high sided, and then came to another stand of water. Go through it or back up? My youngest gets out and says we should go back. I say, look, the cows had to walk through here to get where we want to go and there’s grass sticking up out of the water, how bad could it be? This is the same kid I hit with a mortar on Independence Day and told me not to cross the swamp in J. W. Corbett!
Let’s go I tell her. She climbs back in and I head towards the grass sticking up. We enter the water and get a boat length in and all of a sudden the right side falls away and we’re at a 30 degree list! My daughter later said if her window was open she could have touched the water again. I did what I usually do, panic and floor it! The truck plowed ahead and righted herself as we climbed out with the beeves skedaddling out of our way! Whew!
We drive around for another hour or so, mostly on the trails and staying out of trouble until veering off the beaten path to check out a wrecked and abandoned truck. We drive around it and then on over to look at some colorful beeves so my daughter can take their pictures.
Then the trail seemingly ends and turns to rutted wet grass. We drive right into it and quickly sink and stop! I throw it into reverse, on the first try this time, and back on up until she stopped and started settling again. Then forward and she moves a few feet and stops again. I back up to where she stops, throw it into neutral and shift into 4LO. Then on the gas until we power out of that place but to where? We get out of one spot only to sink into another, in the middle of a soggy bottom marsh! The sidewalls on the KO2s undoubtedly helped get us out of some tight jams. A few yards at a time finding the best way this way and that and after traversing a few acres we were on dry ground. But no road or trail attached!
Another marsh, muck and several flowing irrigation ditches separated us from the safety of the trails. Well, off we went with a running start, got up to speed where the truck shifted into 2nd and we plowed our way through it all and called it a day. The tires quickly shed the mud and once up to speed on the highway there was no vibration as you often get with mud stuck all over your wheels. No, these KO2s pile the mud and cow manure onto the running boards instead!
Back home with supper cooking and the sun coming down we went out and cleaned the old girl. Hit something and popped a “rivet” on the driver’s wheel well and the front bumper was askew. Pushed it back in and reinstalled the rivet, like it never even happened. Well, now there’s a scuff on the air dam. Another story to tell.
Many moons ago I thought it amazing to have a luxury car that one could drive across country in comfort, get great gas mileage and was fast enough to best the quickest sports cars then made. Now I’m thankful that this truck is comfortable and efficient enough to travel across country, can tackle nearly any terrain and still have fun with it at the drag strip.
Shark fin antenna has to be leaking, throws codes for coax cables for the XM/Sirius and Cellular. How does one cheat without dropping the headliner to get at the screw and cables?
More problems related to diabetes. Will know more in another week or so.
HiHoeSilver
Away!
Chicago
Another good one!
From October 2017 through March 2018, with a BlackBear tune and bad catalytic converters, these are the numbers:
E85 = 162.318 Gallons - $345.73 - 1612.9 Miles Driven = $.214 Cents a Mile and 9.937 MPG
Gas 93 = 188.891 Gallons - $598.03 - 2399.16 Miles Driven = $.251 Cents a Mile and 12.637 MPG
Running Gasoline delivers 2.70 MPG higher fuel economy and costs $.036 Cents a Mile more to operate.
From March 2018 through August 2018, with a BlackBear tune and Magnaflow catalytic converters, these are the numbers:
E85 = 222.18 Gallons - $504.72 - 2452.60 Miles Driven = $.202 Cents a Mile and 11.131 MPG
Gas 93 = 212.148 Gallons - $731.08 - 2908.5 Miles Driven = $.250 Cents a Mile and 13.752 MPG
Running Gasoline delivers 2.621 MPG higher fuel economy and costs $.048 Cents a Mile more to operate.
Replacement of the bad cats has resulted in an increase of 1.194 MPG on E85, from 9.937 MPG to 11.131 MPG.
Replacement of the bad cats has resulted in an increase of 1.114 MPG on 93, from 12.637 MPG to 13.752 MPG
In September an updated tune was loaded from BlackBear and we'll crunch some numbers on how well Bonnie Blue is performing on that soon enough.
Anyone do this and also keep track of GPH (Gallons Per Hour) and their Average Speed? I keep track of that stuff too.
a1parrothead
