Long and low
kbuskill
NE. FL.
It’s 4/6 but it’s closer to 5/6. I’m having issues with the panhard bracket on the rear end hitting the frame and also with the front lower control arms hitting the frame. The new bumpstops in the rear were destroyed after the first 15 minutes trip home.
I had the same problem with the panhard bar hitting. I trimmed the bracket on the axle slightly and notched the crossmember for added clearance.
You are running spindles and adjustable struts up front with no spacers I assume???
Same here but I don't have any clearance issues with the lower control arms... at least none that I am aware of... I will have to take a closer look the next time a wheel is off.
I know your running smaller tires so you are going to be slightly lower than me but overall once I notched the rear for the panhard bar she rides pretty good.
Doug118
Doug118
That last picture was exactly what I needed to see. I was going to do the same and box it back in but I assume you didn’t and haven’t had problems?
I just took some measurements and the drop is actually 6/6 after accounting for tire size difference. 28-7/8” front 31” rear
The tire is 1” shorter overall so that’s only equal to 1/2” drop
guy from norcal
Looks so good.
Do you have any popping noises in the rear when you back out of your driveway?
kbuskill
NE. FL.
No problems... and no more knocking/banging from the rear.
Doug118
Doug118
Looks so good.
Luckily my driveway and street are perfectly level but at my aunts house, her driveway is steep and it makes all sorts of popping and cracking sounds
I appreciate all the help. I have to stop being lazy and install the Spohn panhard bar because the rear still sways a little bit. I’ll bang all that out at once
fozzi58
North Jersey
That is bad ass! Way too low for my personal taste as my burb is a DD but if it suits you then more power too you.
You need one of those metal bars installed so you can create a spark show when you drive after you bag it.
Doug118
Doug118
This is also my daily. Right around 1000 miles a week
Man that looks good. I wanna lower my xl so bad!!!
Honestly if I did it again I would go 2/4 with some 24's or 26's. This drop is just way too much of a hassle and it's not as simple as bolt together and go
Doug118
Doug118
I've seen lower static dropped silverados but I've yet to see a static dropped SUV sit lower than mine. Tubbing the front fenders and doing an under-body c-notch are the next steps
Doug118
Doug118
So I have some freebie 22’s and finally got some free tires. I was really excited to get them mounted up. Took the truck for a ride and smoke is pouring from the front drivers tire, it’s sitting on the fender
sanco
Chicago
man that thing is loooooowww lol, looks good man
Doug118
Doug118
This is getting good :)
What are your plans?
Man, that looks good.
The front will probably stay where it is since I hit the front bumper at least 3 times a day. The rear I’ll cut the springs until I get it sitting level with the front. It’s going to stay static. No bags anytime soon
Durobans
