bottomline2000
I'm running the same AEM wideband as you and I have mine tapped into my pcm at my EGR port. You can monitor AF by the 0-5v output but if u using a dyno save your time and keep the one you have. Probably safer to dyno tune a boosted engine anyway.I've decided to just strap it to the dyno and get it tuned rather than going the remote route since ultimately it would still need to see a dyno per most tuners statements. That will be getting done tomorrow. I will use my HP tuners so I can utilize my credits and we will use the wideband connected to the dyno for tuning purposes. Upon completion we will install mine back in the downpipe to monitor AFR's in case anything needs to be changed between the dyno/street driving.
they are finicky im sure its a blast to drive
