Kbuskill's 2008 Burb LTZ "MOD" Thread
kbuskill
kbuskill
NE. FL.
I think it's the Power and the Ground that I would like to see. Like I said, I'm not too savvy on the electrical work, especially in a vehicle. I can change a light switch or a plug in a house, but past that....
You need a tilt switch... something like this...
https://www.amazon.com/NORMALLY-OPEN-CLOSE-TILT-SWITCH/dp/B073HNMCMN
Attach switch to hold securely so that it doesn't bounce around and cause your light to come on with the hood down.
One side of the switch goes to the positive lead of your new underhood light. The other side goes to the power coming out of the fuse tap/fuse box.
Get a fuse tap like this...
Tap into the underhood fuse box here...
Fuse number 37 front wipers 25A.
Ground to just about any bolt under the hood.
wendal
Dallas
kbuskill
kbuskill
NE. FL.
05Single
afraid of the dark
Caught all up , nice work on the sequentials . Need diagram in crayon or something and link for them unless I missed that. I went from 60smd type 1 switchbacks to now jdmastar type 2 switchbacks and love the light pattern waaaayyy more. The ones I got were listed on jdmastars eBay page for $30 (or best offer) on eBay, threw them an offer of $25 a pair for 2 pairs and saved $10.
Hood light is such a nice upgrade for our trucks, even tho gm and all other manufactures cheap out on that part. For my hood light it's the simplest install but nobody uses it for some reason lol. I just grounded to a security/alarm adjustable hood pin. Then straight power to battery with inline 20a fuse. Led cob strip about 6" long.
kbuskill
kbuskill
NE. FL.
Hood light is such a nice upgrade for our trucks, even tho gm and all other manufactures cheap out on that part. For my hood light it's the simplest install but nobody uses it for some reason lol. I just grounded to a security/alarm adjustable hood pin. Then straight power to battery with inline 20a fuse. Led cob strip about 6" long.View attachment 204153
The JDMastar bulbs are the ones I have had my eye on... those will be the ones I go with when I finally pull the trigger.
These are the sequential modules I bought...
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/142680629281
They seem to work pretty well. Just a heads up though.... they don't come potted or sealed so I would strongly suggest sealing them with something before installing to prevent water getting to the electronics inside.
Wiring is straight forward.
Power from turn signal to 12v input on module.
Ground to ground input.
Module has 4 wires coming out...
Flash one, flash two, flash three, and ground.
Hook them up to the bulbs you want to flash, in the order you want them to flash.
I thought about the pin switch but already had a tilt switch from my old box body S-10 blazer so that's what I used.
05Single
afraid of the dark
They seem to work pretty well. Just a heads up though.... they don't come potted or sealed so I would strongly suggest sealing them with something before installing to prevent water getting to the electronic inside.
Thanks and yea super duper easy install for the turns.
I also had my hood pin left over from previous remote start so I used that lol.
Jdmastars are super super pure 5000k white not a tiny bit or hint of blue, same color as new 2017+ Sierra/Silverado drl strips or new Durango drl strips. if you're wanting to matching in the front. Here's an example of the color.
kbuskill
kbuskill
NE. FL.
Jdmastars are super super pure 5000k white not a tiny bit or hint of blue, same color as new 2017+ Sierra/Silverado drl strips or new Durango drl strips. if you're wanting to matching in the front. Here's an example of the color. View attachment 204220
The ones I have in there now are basically identical to the JDMastars the just are a type 1 LED. But as far as the color match goes it is spot on.
This pic was when I still had my 8K HIDs in the low beams...
I have since swapped the low beams for the Supernova V3 LED headlights so they all match except for the high beam... haven't figured out what I want there yet.
Low beam, parking lights, projector fogs all LED.
sarneson91
Alexandria, VA
I wish money wasn't so tight right now... I have so many ideas/plans and NO extra fundage for the cool.
Ever thought about doing 3rd lights as a side job or setting up switchbacks for people? Like getting a package together and making a diagram for install purposes? Just thoughts, I'd love to have a esky 3rd with some kind of chaser
kbuskill
kbuskill
NE. FL.
Haven't really given it much thought honestly.... there used to be a couple of guys on here that modded the Esky 3rd brake lights.
Now you can buy a full width Esky 3rd off EBay for pretty cheap. It is a lot of work to open them and modify them which is why it cost so much to have it done... time is money as they say... lol
Not sure how good the ones on EBay are.. never seen one in person.
05Single
afraid of the dark
Projector retrofit , I figured it out for yea lol
kbuskill
kbuskill
NE. FL.
Don't think I haven't thought about it.... it may happen one day but I would buy new headlights to do the retro on so I wouldn't feel rushed to get it done.
kbuskill
kbuskill
NE. FL.
Well I guess I've gone and done it now.... got bored and ordered up some new parts.
Got the new type 2 switchbacks for the front end and ordered up all the parts needed to change up the Esky 3rd.
Now we wait for deliveries I guess.
I really want to swap the high beam bulbs for something else but I'm just not sure what that is just yet.
kbuskill
kbuskill
NE. FL.
Deliveries seem like they are taking forever... it's like waiting for Christmas... lol
I did get some things in... I went ahead and made up these weatherproof connectors so they will be ready when the rest of the stuff finally arrives.
Pretty boring I know... but at least its something.
BadDaddy2003
