my tahoe pretty much sits parked all week, all but on weekends or when i need to take my mother to a dr appointment, today was a dr day, its super hot today had the air blasting sitting in stop and go traffic the whole way there, then as i park and put it in park im hearing this roaring sound ive never heard before, im like wtf broke????
then i realized it was the fans on high speed screaming. felt much better after i put 2 and 2 together.
never heard fans so loud before. they was a humming good lol
I want to do this so bad. I have everything I need, just need the pins turned on in the pcm.
Scottydoggs
NJ
its tuner time my friend.
what year you got? if a 05 i can add two credits and unlock the whole year. then tune any 05 tahoe. or its just two more credits to unlock your pcm if a different year.
Unfortuneately it's an 03. How much would it cost? And I guess it could be activated and still use the clutch fan too, until I put the fans on?
Bombsquad85
Northern VA
Replaced my front blower fan resistor today. It didn't work. Weird part was the one that was on it looked like it had been replaced already and had melted. When I installed it I checked connections and still nothing. Does this mean it's the blower motor that crapped out on me?
Here's a photo of the plug that goes into the resistor
I'm sick of this shit. It crapped out a week or 2 ago and it's been consistantly 95-100* out luckily the rear ac works so my son doesn't cook
HiHoeSilver
Away!
Chicago
Oh hell yeah, that's a wining look.
Nice work.
Okay. Here's what I got on the sides. You can see that the top cap is as close to perfect as it gets with the fender /wheel well. But because it's riding outside, it pushes the denali part back. Not bad from 15 feet, but up close, it's clear it doesn't line up. Thoughts/ideas ?
Is there power going to it? Are you able to test the blower motor itself?
Scottydoggs
NJ
credits are 50 each, so 100, unless i go out and buy a bundle of credits. there was a sale a while back, 10 credits for 350 or 400 iirc. was gonna jump on em, but decided not to.
pretty sure the clutch fan would hit the electric fans if installed. or be really close. like to close for comfort.
No, what I mean if I get the electric fans turned on in the pcm, that I could leave the clutch fan on until I finally, physically bolt the electric fans on. The clutch fan would still continue to work correctly? I was told they would, just double checking.
Scottydoggs
NJ
oh lol yeah no reason for it to not work, its a mechanical part, no computer telling it when to lock up.
ive not done the fan swap. you need to add pins to the pcm plug? if so i got pinned wires for the pcm.
Yup, for mine it's 2 pins added to the pcm. I have everything that's needed.
Scottydoggs
NJ
HiHoeSilver
Away!
Chicago
A little heat maybe? Kind of stretch it some?
I thought about it. I don't know that there's anything to stretch, though. And it's not that the top isn't long enough, but the bottom is too long. I can muscle one side to one it all up, but then it pushes the other side worse (of course). I think imma have to cut more....
05Single
afraid of the dark
View attachment 203560 View attachment 203561 View attachment 203562 View attachment 203563 View attachment 203564
Follow the line down and match it, there won't be a lip but if you black the rest out it won't be noticeble. Doesn't effect durability or structure integrity.
HiHoeSilver
Away!
Chicago
Follow the line down and match it, there won't be a lip but if you black the rest out it won't be noticeble. Doesn't effect durability or structure integrity.View attachment 203588 View attachment 203590
I think this is the plan. Here's the trouble with it...
I can go down to the horizontal line and keep the fastener, which is right about where the right vertical line (yours) goes, but then I'm missing the wraparound into the well. I think I'm going to need to cut a wedge like so....
I'm going to have to silicone, or glaze, or (I really don't want to) glass some stuff already. I can get that corner to look good I think and still have continuity inside the well.
Phlipnstik
