treehan77
TYF Fiend
I am having the issue where i can't fill the fuel tank (other than extremely slowly). I tried changing the evap solenoid, no improvement, old one seemed clean and bench tested fine. I have a canister on the way, but i don't know if that will fix it or not. There were a lot of pellets spilling out of it when i removed it. I'm worried these may have got to the other end of the lines above the tank and plugged it up.
Can i drive with the solenoid and cansiter removed? I think if i can fill up normally without it, id know it was my problem; otherwise I guess i'll have to pull tha tank.
Does anyone know what the little rubber line that has a what looks like a stopper on the that runs up near the filler neck but doesn't connect to anything do/for? It had a small tear, which i fixed, no improvement. Only code has been p0455 evap leak and the tighten gas cap message. Erased the code, hasn't come back yet, but can't fill still.
