corvette744
2004 Z-71
Never mind i adjusted my gear box 1/4 turn clockwise and it made more difference than any part i have changed on the suspension to date.Best free mod i have ever done.Unreal steering now
Make sure to follow the advice in the thread about not over tightening or you could damage the gearbox. Never more than 1/8- 1/4 turn seems to be the consensus.https://www.tahoeyukonforum.com/threads/sloppy-loose-steering-fixed.46957/ follow this thread very simple to do-5/8ths wrench or 16mm and a 3/16ths allen and your done.Pop your hood and look down between your upper hose.
View attachment 203142 View attachment 203143
Thanks for the help!Make sure to follow the advice in the thread about not over tightening or you could damage the gearbox. Never more than 1/8- 1/4 turn seems to be the consensus.
Thank you for the help will do this tonight!!https://www.tahoeyukonforum.com/threads/sloppy-loose-steering-fixed.46957/ follow this thread very simple to do-5/8ths wrench or 16mm and a 3/16ths allen and your done.Pop your hood and look down between your upper hose.
unless your steering box is completely worn it it can definitely help.I have the same issue. Did this really work?
or just delete it.Resurrecting an old thread. Seems like there are two issues: 1) loose steering and 2) over sensitive / variable assist issues. I have a 99 and had the variable assist issue back when it was new. Not sure what happened but it seemed to go away. Now, 20 years later I do a lift and larger tires, and the issue is back. Front end is completely new and aligned. The steering issue is back with a vengeance. I'm thinking the larger tires have changed the resistance it is sensing? Anyway, I need to fix this once and for all. Feels darty and unsafe. Have to constantly pay attention. Is it officially solved? that replacing GM Part number 26084178 fixes the variable assist issue?
This^^^^or just delete it.
IIRC you can try unplugging it and seeing if that makes a difference before going through the hassle of installing a new one.
I just bought a '00 Yukon from Texas that is RWD not 4X4 like my '00 Tahoe. The steering on the Yukon is completely different than the Tahoe as far as the ease of steering the Yukon takes more input at slow speeds than the Tahoe might have something to do with 2 wheel drive vs 4X4 not sure but the two are very different that is for sure. I actually like the ease of the Tahoe better at slow speeds.John, you hit the nail on the head. It requires too much concentration on the highway just to keep in lane because there is no centering feel. It does seem to be less of an issue since I installed to Hydra Boost. (How can it be Hydro Boost when there's no water in it? Hmmm?)
You eventually get use to it but it takes a while.Having the same issue. All parts are new and the steering is still so sensitive I can even look away at the rear view mirror for fear the car will go off the road. The power steering is just to strong. Zero feedback. Has anyone tried restricting the flow? If so, what side you use?
It’s for a Mustang 2?So I finally got tired of white knuckling on long trips so I fixed the problem 100%. I replaced the orifice on the back of the power steering pump. It’s called a “Mustang 2 power steering flow valve”
P/N 91032918. Made by
“ Speedway Motors”.
I ordered it on Amazon. I am super stoked!!! 100% fixed the sensitive steering.
I didn’t see where he mentioned he had hydro boost?I'd be worried that reducing the pressure would affect braking assist.
