AC doesn’t feel cold
Illnasty
New Jersey
I feel that my AC doesn’t blow as cold as it should. Any idea what the temperature should read on full blast cold?
Tahoe14
Central Fl
What year, 15-17 had the condenser issue which would cause the AC not to be as cold as it should be. Warranty was extended to 60,000 miles. You could buy an inexpensive AC gauge and place it in the AC vent to see what the temp is.
Illnasty
Illnasty
New Jersey
2016. FML, live in NJ and we have 90 degree days for the next 6 days and house AC is broken, 2002 Denali AC is broken, and 2016 Denali works but doesn’t blow that cold. I may die from heat exhaustion so it was nice knowing all you guys. This site is great so keep marching on.
nrcpharmd
Florida
Just had this happen on my 15 Yukon XL Denali, ac won’t really blow cool at idle, running it cools alright, but not like it used to. Any suggestions?
Tahoe14
Central Fl
See if your loosing freon from the condenser. Common problem. Just do a Google search and you should see pictures of where the leak is located.
nrcpharmd
Florida
So AC starts working again this AM, thinking it might be blend door actuator, rear AC definitely working well. Any idea if anyone else had issues with blend door actuators on 15+ GMs?
nrcpharmd
Florida
On further investigation I’m thinking it’s the front temperature blend door
Strip5150
Mine is in the shop for exactly the same thing over the past week. 48k miles. AC condensor covered under warranty!!
nrcpharmd
Florida
Looks like I’ll be making it to the dealer to have it looked at. Not sure why the back cools great but front works like crap, morning it cools off, evening it cools off, but middle of the day when I need it, I get nothing unless I’m moving, blows hot on idle.
Strip5150
Mine did that over a week or so. It was a leak in the condensor. 100 degree weather and I couldnt take it anymore.
Just got it back. Almost need a jacket in the car even though its in the low 90s outsided
nrcpharmd
Florida
In for the condenser, hopefully ready in the next few days
TahoeFL2017
That's awesome, good to hear.
Mine was not blowing cold this past July, dealer fixed under warranty, I am in Florida, and have to dial it back after 20 minutes, it gets that cold.
We test homes AC's on properties we list for sale, houses should blow 17-22 degrees colder than "room" temp, if you aim a cheap Home Depot laser thermometer at the vents. I assume its the probably similar for Tahoes, which are pretty much a condo on wheels lol.
AC is a sealed system, freon loss is not normal, unless extremely minimal, never should have to really "top it off"
dizhai
