Gears for our 4x4 hoes!!!!
99COOP
Retired
Chicago, IL
Whats the brand? unless i missed it, i would only go w/ well known/reliable brands. The last thing you want is to spend 1000 bucks on gears, locker, and install only to have them whine every time your coasting.
btw, are you sure you wanna run a locker in a DD application ?
bowtiefreak
No Quarter
Near Philly
I agree with 99coop. A locker is tough on a DD and get some decent name gears. I am running yukons and they are great so far.
1weasel
Laramie, WY
When I was looking to change my gears, I ran across this page:
http://www.4lo.com/calc/geartable.htm
That page said that I need 4.27 gears for my 33"s to get back to stock gearing. Does that sound correct? But when I did the quick calculation (.12*33) it came up with a 3.96 gears, which I guess puts it between fuel economy and factory ratio. I'm pretty sure that I have 3.73's in there now (from the code)
bai78
Surviving
Dallas, TX
Motive gears.
If you are going to stay with 33", just do 4.10's & call it a day. If you want a bit more umph do 4.27. It is a bit harder to find 4.27 for the 8.25 front diff but 4.10's are abundant. Now if bigger is in the near future like 35"s, do 4.56. It's just my 2¢ as I have run both 33" & 35" with 4.56 gears.
Chevyrider619
Virginia Beach
I'm running 35's with 456's and their good..456's are good for road and off road(wink wink) not the greatest gas but maybe someday u might wanna go bigger those 456 will come in handy my 2cent..
Landchipper
AL
X2
I agree with Bowtiefreak get the YUKON set for strength and
quietness of function. Cheaper sets have a tendancy to roar
even when new and installed correctly. My 0.02$ worth.
loulblades
Western PA
Those calcs are for 1:1 manual. Don't forget your overdrive if you are looking at highways speeds.
MUDDER TRUCKER
port huron,mi
x2 456 not good on gas but great off road, thats what i have and 38s,eaton locker in rear
Landchipper
AL
I am looking into the 4.10 for better fuel economy and if I need offroad
performance I will put it in 4Low. It is not like my grocery getter will be
doing any rock crawling or mudbogging either for that matter.
mickbozard
St. Matthews, South Carolina
Has anyone ever thought about a two speed rear ? A fella could have beauty of both worlds.
1) 2wd place rear in High gear for gas mileage let's say 3.73
2) 4wd place rear in equal ratio as front (Low gear) 4.88 or 4.56
Is there even a small 2spd rear out there that could do this trick ?
fyremanpat
Fyremanpat
thats my next big step I think..Ive got 3.42's...fml..and my wallet
newmarketeod
Read into underdrives, they go between the transmission and transfercase and do something similar. When dissenganged it is 1:1 so it is factory gearing but when engaged it switches to another gear ratio like 2:1 for better off road gearing.
Due to the fact of all that has to happen in a rear end a small two speed rear end wouldnt be feasible and still have any sort of strength.
Conedaddy
