Brake Upgrade
Stephen Ludwig
2017 Yukon XL Denali. 22’s. Looking for brake upgrades including color calipers. Found a few but unsure if any better than what is on truck now. Anyone have any advice?
jeff laing
I just installed the big Wilwood kit with 6 and 4 piston calipers, runs like 4K with lines
07 Denali
Hadnt seen those. I’ll take a look
I’ve got the Wilwoods as well. Fronts are installed and backs are waiting for the safety wire tool to be delivered so I can secure the hat bolts. Love the fronts so far. Big improvement over stock...especially if you actually have to use them.
S
Stephen Ludwig
Going to grab some. Look good and great reviews.
Stresst
Brembo makes a kit for GM for like 2500 for the front.
Shadowchaser
NYC
I just upgrade my rotors and brake pads R1 Concepts best quality highly recommend it .
Brake Rotor SKU(S): 633-48050L,633-48050R,633-48053L,633-48053R
Position : Front and Rear
Add Ons :
Brake Pads : 1551-1363-00(Front),1551-1194-00(Rear)
Brake Hardware : 340-46016(Front),340-47054(Rear)
CHEVROLET/TAHOE/2015/ Without Police Package
Total:$416.2
HiHoeSilver
Away!
Chicago
Add Ons :
Total:$416.2
Are those Eline or Geomet?
I did the Wilwoods BBK as well and when I saw the instructions for using safety wire I got ahold of them. They told me they had to do that because the brakes are race rated and that's a track requirement. For the street, you can just loctite and torque them. Just an FYI in case you get frustrated trying to wire them. You can ask Wilwood yourself if you like. Safety wire will only keep the bolts from falling onto the street or track, they won't keep the bolts tight. Nothing else on our trucks has safety wire lol.
07 Denali
Good to know. Actually Great to know. Ordered the tool (which I’ll likely never use again) and started last night. One rotor and hat done last night. Might as well finish the other one today. It’s fun to tinker.
It didn't look like it would be easy.
07 Denali
Definitely can’t do it without the tool. I messed up a couple of times. It’s not perfect but should do. Glad to know it’s not do or die if they’re not perfect .
bradntx
Anyone with the Willwoods want to give a report on braking performance? I am already finding myself wanting a little better braking than stock. Does anyone think it's worth the $4k? Would you do it again?
I don't think you could stop one of these rigs any faster. The 16" /14" rotor combo is huge especially the fronts with the ginormous 6 piston calipers. Whether they're worth $4k is subjective I suppose but if I could afford to I'd put them on without question especially if I was hauling a family around or towing. There are more expensive options out there as in Brembo. I would do it again.
Do these BBK's fit the factory 20"x9" 5 spoke factory wheels?
The minimum wheel size is 20" but you need to look at the diagrams and measure. I know it depends on the design of the wheels as to whether the caliper clears. Sometimes it's not the diameter that's the problem but the spokes. My 26" Dubs are closer to interfering than are my 22" reps. Wilwood's website has diagrams with dimensions you can check.
07 Denali
View attachment 199914 View attachment 199915
I agree with everything Rocket Man said in regards to braking performance. The only thing I can add, which is subjective, is the braking “feels” more mechanical. Not as soft and cushy like stock, but more like you can feel the pads making contact with the rotor under your foot.
MotionHz
Nj
Hi also looking to improve braking. Will be looking into the Wilwood and Brembos. Surprised they were that much for some reason. Looking for new wheels as well. Have to figure out what works with the bigger brakes.
Drewphil
