17 Yukon XL Denali Brake Pull and Grinding
matttbyrne
Another day, more front end issues with my 17 Yukon XL Denali. When I brake hard, and am just about to stop, I hear what sounds like brake pad metal on rotor from front passenger side. I just put on new calipers, pads, and rotors in the front and the old pads and rotors still had lots of life (I did an upgrade since I wanted heavier brakes), so I know it is not low braje pads brakes. Noise was there before brake upgrade. When I come to a stop with no brakes, no noise. When I press on the brake and accelerator at the same time at low speed to put a forward load on the suspension, no noise. I think the noise might be related to the front end dipping when breaking hard. Also, when I jam on the brakes at highway speeds, I get a momentary pull to right that only lasts a fraction of a second before she straightens out everthing brakes normally. I thought the pull might be tire inflation related, since right tire is 29 while left is 30. Because of another problem, I have replaced struts, sway bar links, sway bar bushings, and cv joints. While my first thought was bearings, the facts that the noise is not there on a coasting stop, or when pressing on brake and accelerator, makes me think it has to do with dipping of front end. Thanks in advance for any thoughts.
Welcome to the Forum from NH.
Pics of the truck, please.
Did you use a quality bi-directional scanner to air bleed the ABS system after you did the brake work?
BadDaddy2003
