10 bolt to 14 Bolt, 9.5 sf swap
randeez
south florida
Couldnt find much on here, usually gets shot down and told to build a nice 10 bolt :anitoof:
Won't be so much of a DIY as it will be the first I've done, closest swaps i've found have been on avalanches mostly. If everything works out I will clean up the thread and probably leave the stuff i've done wrong so you'll know not to make the same mistake.
My truck: 2012 yukon denali 6.2, AWD, 6l80E 10 bolt, 8.6, 3.42, G80
Axle out of: 2013 escalade 2wd options AXN (9.5 axle) GU6 (3.42 gear) G80 (gov lock) should be here monday, I am going to try and have everything I may need on hand for a quick swap next weekend, driveshaft willing.
I've compared all the brake parts they all match, All the link bars should match up, I have the spoon panhard if that needs to be adjusted. There is a conversion ujoint available that has the stock driveshaft side to 1350 joint on the 14 bolt yoke, *IF* the driveshaft doesnt need to be shortened drastically it will atleast allow me to keep it on the road while custom/balanced driveshaft is built. From what i've found the 14bolt yoke is about 1" more forward than the 10bolt. some have thrown in the conversion ujoint and no problems but I havent been able to verify it will work specifically for my swap with the AWD case.
I don't remember the guy having to shorten his original driveshaft when he put the AXN axle in Randy (Performance Trucks article).
randeez
randeez
south florida
lets hope! between it being closer and me being lowered a little bit it straightens out the driveshaft i dont know how much i'll be able to get away with.
conversion u-joint "1350 to mechanics 3R", yukon part number YUJ1153
randeez
randeez
south florida
Axle showed up, had it delivered to friends shop so we could install on lift.
Axle looks great, reported as 26k miles and looks clean. Didn't do me any favors past that tho- cut the flex line to calipers (no calipers) and for whatever reason cut all hard brake lines on the axle, bent the hell out of the dust covers/backing plates, cut the speed sensors right before the connector.
Going to clean it up, slap some paint on it. Ordered the PML cover and lube locker gasket, ordered the conversion ujoint but I need to crawl under as it sits and try to determine what end is on my driveshaft. Going to do the charcoal canister while I'm there too
And I need to move the driverside mount of the sway bar over.
Have you thought of consigning the charcoal canister and all its related parts to the garbage can and turn it all off in the tune?
Let me know what you think of removing that swaybar bolt when you get yours up in the air. Once the bracket is off, the bolt is broke off proud. Do you think heat can break it loose without damaging anything? It's the front bracket, passenger side, rear bolt of the two if I remember right.
randeez
randeez
south florida
Sounds like not a whole lot you can do. Start drilling it out. I had a MFer of a bolt stuck in a turbo housing burned up probably 15 drill bits new/old anything I could find, different materials...got about 75% of the way thru and ended up just beating the hell out of it with a center punch ripping up the last few threads :lol:
I busted off an easy out and then $60 worth of specialty drill bits within minutes. Hoping heat can break it loose and then use vise grips to remove the rest. Can't do much right now anyway, back injury flared up again.
kbuskill
NE. FL.
I would find a nut that will either thread onto it or slip over it and weld it to it and then see if the heat cycling of the welding process wouldn't help to break it free.
randeez
randeez
south florida
So mech and I were trying to make sure we had the correct ujoint. He had a 1310 to 1350 one. Compared it, it definitely looked like both , the stock driveshaft and 8.6 yoke, were 1350. He called a few places. Couldn't confirm, said f it and pulled the stock driveshaft out and set it in the 14bolt yoke as it sits, just needs straps.
Soooo as a side note, the 10 bolt 8.6" I have now, has a 1350 yoke on it:shrug:
My driveshaft still looks like hell I will get a built and balance aluminum one anyway
randeez
randeez
south florida
Been scratching my head about it for a few weeks. ive got a 1350 to 1310 and a 1350 to mechanics 3R conversion joints, that's why we finally just pulled the driveshaft and set it in the 14 bolt yoke.
The smaller ujoints all have inner clips to keep the caps on. Mine just has outer clips on the driveshaft and tab/strap on the yoke
I keep coming up with a 23104840 for the u-joint on the 9.5, same as our front. Our rear u-joint is 89059111, a 1350. The 23104840 crosses to a S-44 and 5-795X.
I've been working on the yoke and slip yoke and driveshaft numbers as well. Have to stop as my back is really acting up now and pain meds are kicking in.
randeez
randeez
south florida
/\ i keep chasing my tail on it bud, i'll see if theres a physical part no on ujoint when we install it. but right now i'm convinced the stock ujoint that is in there now is going to work fine
randeez
randeez
south florida
welp, kinda uneventful. everything swapped right over to it.
brakes - caliper brackets, calipers, pads, hardlines just needed to be massaged a little over the pumpkin.
5 links bolted right up- uppers/lowers/panhard. panhard is very close to the stock cover on the 14bolt, may not be able to use cover with spoon adjustable
shocks mounts exactly the same with belltech extenders worked perfect.
and driveshaft already had correct u-joint from my 10bolt.
That's awesome, going to do that to mine someday too. Have you thought about putting in a 4x4 transfer case like the MP3024 from the 2500s?
randeez
randeez
south florida
if I ever kill it dont know... I am probably one of the few that enjoys just having full time awd. If i get to the point where it simply wont handle what i throw at it then sure, but i would probably just go 2wd before.
old 10 bolt atleast needed axle bearings/seals, wasn't much slop in the carrier but still happy all went smooth took 3-4 hours for the swap from the time i drove in till the time i drove out
I thought the other case might allow you to run even faster besides giving your more options. Glad it worked out just fine. Gonna keep the old one for a spare or sell it off on CL?
randeez
randeez
south florida
it's kind of "payment" for helping with the swap he is going to hang onto it, has a single cab he wants to 4link. he may eventually do a 14bolt for it but mocking it up with the 10b will make for an easy upgrade later.
brice715
