Show off your 2015-2020 lowered tahoes and yukons
crober9
Installed the NorcallSS level on my Yukon. Rides well but it has a 1" rear rake I have to get out. Will the heater hose trick pull it out? Planning on debadging tomorrow.
olyelr
Elk Rapids, MI
View attachment 194450 View attachment 194451
What is your current configuration now, the springs and 1” spacer?
From my understanding, the heater hose setup is to be used when the upper coil isolator is removed.... to gain more drop.
Why not just lower the front a little bit haha.
Kpwweb
It won’t pull out 1”. Like said, you would need a 1” front drop for that.
I did heater hose and it pulls out about 1/8” per isolator (depending-because the isolator compress). So with upper and lower isolator you can get 1/4” to maybe 3/8”...
Pivot
Nice looking trucks, everyone. I prefer stock height on my trucks cosmetically and functionally, but you all do have some nice looking rides.
:cheers:
Sahidblack
