2004 Tahoe bose questions.
hepp04hoe
hey guys I have a 2004 Tahoe with Bose, no sub, xm and onstar. question is, I am going to be replacing the head unit and the door speakers. I want to get rid of the bose amp. why you ask? when it's col, below 30 degrees I have no sound, until the inside of the hoe is nice and heated up and in Iowa that is all winter, which sucks! I will eventually be adding a 5 channel amp for the componets and sub when I get the money, my question how do I loop around or bypass the bose amp? I have done lot of reading and searching and haven't found any clear answers. thanks!
If I'm not mustaken @05Single had a thread on this. He had a little diagram of just unplugging the amp and just splicing orange/orange, red/red etc, from both plug ends. Hopefully he'll chime in.
All i found in my research was people just ran all new wires.
I never had a problem with mine in the cold but i heard others having the same common problem.
Also if you have bose you do have a sub. Its under the cup holders. Or if you have no bass then its blown
Heres my thread
http://www.tahoeyukonforum.com/threads/03-bose-bypass.101546/
Ran them complete? From end to end, or just from plug to plug once the amp is pulled out?
M1Gunner
Gainesville, Fl
And are you sure you don’t have a sub? My 04 has a sub tucked away at the very front of the center console NOT inside the cargo area panel. You have bose speakers and amp I’m willing to bet you have a sub.
H
hepp04hoe
okay I thought the only sub was in the rear cargo area. if there is a sub in center console it Is either really weak or blown up lol. thanks for the answers guys good stuff to look into!
EricBeau
