Transfer case output seal leaking again
dman76
I posted last year about replacing the transfer case output seal on my 2000 Tahoe and thanks to you guys, it was a pretty simple process. I did check it for several months after to make sure it wasn't leaking and all was fine. This weekend, I just happened to look under the truck and noticed some grease buildup on the frame and tracked it back to that seal. I could see a little drop between the rubber and the flange (rather than between the flange and the transfer case) so it looks like the seal is leaking again. Since I replaced all of the fluid last year, do I need to drain the transfer case fluid to change this again? I am not sure if it will just come pouring out when I remove the shaft, or if the fluid is elsewhere inside. Also, any tips on hammering the seal in? I remember last time, I found some blocks of wood and cut a whole the size of the seal in it and put it over the seal and hammered the block. Any better methods? Thank you.
Erickk120
You mean the seal for the front driveshaft output right, the two piece seal? If so I just redid mine a couple of months ago, that seal is a pain in the butt to remove with conventional methods. If not impossible, unless the tc is out of the vehicle and even then it would be hard. What I did was I used a screw and screw attachment that came in for my slide hammer. I screwed the screw with my cordless impact, pulled it out again and added the attachment, with the screw in the seal. Now that the hole was threaded by the screw. Attach the slide hammer and pull with all your might and it will pop with a bit of persuasion. That is the easiest way to pull it out in my book, without having a bad frustrated day. As far as installing it without damaging it? They sell a two piece seal installer, but you can get away with using something that fits the outside perimeter, I used one of my race installers and a good size hammer with short handle. It takes effort to make it pop in. Have a catch can ready since you will leak about a quart of fluid, so make sure you buy some acdelco auto trak before tackling it, unless you use tranny fluid like some people do. I changed mine about 2 years ago and it started leaking, I blamed the cheap seal I used before. So, I went with a good quality one this time. If it leaks again it's definitely the bearing behind that seal, and I would have to replace them all. So far it has been about 6 months and it is bone dry. Also if you go this method make sure you don't go too deep with the slide hammer screw attachment, because the bearing sits right behind it. The screw is to be screwed between the outer and inner area of the seal. So that it pinches both sides of the seal without damaging the surfaces of the tc. GL.
D
dman76
Correct, rear output. It is very easy to get off. Do I need to drain it though?
D
dman76
Hello again. I am just checking back here because I am about to do this and was hoping to get an answer. Do I need to drain the transfer case fluid before pulling the shaft to replace the rear output seal? Also, what kind of grease should be used to grease the shaft when replacing it? Thank you.
Shaw520
Erikk quoted above that you will lose aprox one quart when you pull the seal,...replace with whatever fluid you used prior.
D
dman76
I think Erikk was talking about the front seal in that paragraph above. I am referring to the rear seal.
Wildhorse
I always replace the bushing with the seal. Your bushing is wore out letting the yoke hang down on the seal instead of nice and straight. Every new seal will leak until it's fixed. Like a bent rim....u can keep throwing new tires on but it's still gonna leak!
D
dman76
Thank you for that advice. Is that a difficult process? I know nothing about that procedure but will do some research later and if I can't figure it out I'll come back here. Thanks again.
Chubbs
great suggestion @Wildhorse
It doesn't matter how many times you replace the seal, the output will continue to leak until all of the underlying failures are addressed.
I haven't been into this TC yet, but have seen the inside of more than I wanted to.
Always inspect the actual output shaft and the bore which the seal lives. the bore or seal housing must be clean & smooth. Same for the shaft. Always clean and thoroughly inspect all of the components. A seal will not "seal" if the shaft or housing is marred/contaminated/pitted. If you get everything disassembled to find something suspicious, do an Internet search or come back with pictures so that we can assist you. once again, take your time, clean everything with alcohol or solvent and get some good light shining on your work area. Detail is the number-1 priority when it comes to gasket & seal. You have to properly remove the old/leaky seal to begin with so that you don't F*ck up the bore (contact surface) with your tools trying to pry it out. Wipe everything down good as new and make sure it can go back together without any extra steps for refurbishing the surfaces. Always lube both outside AND inside of replacement seal to ease assembly and prevent any damage to the new seal surface.
Doing this R&R all over again so soon means that you missed something last time so just be prepared.
The block of wood works fine, so long as it fits the way you crafted it. Large sockets do the same thing, PVC pipe, specialty tools that are usually waaaay overpriced but could be found @ bargain via Amazon/eBay. NAPA is the worst when it comes to price gouger.
D
dman76
I remember cleaning the yoke thoroughly with alcohol and making sure it was smooth and cleaning where the seal goes before installing it. The leak appears to be coming out of where the yoke goes into it as opposed to where the seal was pushed into the transfer case. Would a way to check the bushing be to grab the driveline and see how much play there is when you try to move it around?
Doing a quick search, I found a few videos showing the removal of the transfer case to replace the bushing. Is that correct? Is this a pretty big project that may be difficult, especially while not having a lift ?
Drewphil
