Chubbs
Clay bar'd and sealed the paint. It desperately needs a paint correction, but it's a daily so not sure how much more effort I'm going to put into it. The Pewter doesn't shine much more with a good sealant on it anyway.
You know what? I just did the wash with a mitt, wipe down using PVA towel and hand waxed with Mother's Brazilian Carnauba. It looks nice for a few days but I don't care about that. My main concern is protection from the weather, ozone and tree sap most of all.
I used the clay bar on a project several years ago but I keep forgetting about that product & method. Say I get around to spending time on this truck in a few months again, what all should I do to it? I suspect that it will rain pretty regular for the next couple months but come June it will be around 100* everyday and I try to park under the trees to keep the truck protected from direct sunlight all day. I like for the finish to shed water extremely well but I don't feel like working on detail again any time soon.
I remember reading that if done properly from start to finish, a good sealant will provide protection for nearly a whole year. That's what I need
rabidcoyote666
Lake of the Ozarks......Mizzouri
washed, waxed and detailed.....then it rains.....lol
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
@ArcticYukon
Eventually, the app will cease to function entirely. The ambient temp may contribute to the sensor operation at the present but 1 day it's going to quit at the worst possible time.
You are correct, spending time on the TB does nothing for the APP but I don't understand why you aren't repairing the problem. Is there not an auto parts store where you live? You could have ordered it on eBay or Amazon & had a new app sensor in your mailbox. I'm just not clear on that.
The app sensor went out on my truck, REP message, 1 fault code that I pulled for the app sensor. I bought a replacement sensor @ oreilly auto that night, along with a kit of security torx bits that have the indentation in the center -- removed the acc pedal, R&R the sensor, problem fixed.
My boss at work was trying to get me a replacement TB at first but I talked him out of that and my truck was parked on the lot next morning courtesy of pedal sensor per the DTC code.
Know what, man? I was searching on Rock Auto for it and because I couldn't find it on there, I ASSUMED I wouldn't be able to find it at a local parts store. Turns out, I was looking in the wrong place on RA (it's under the interior section for whatever reason) and the local stores have 'em too. We all know what happens when you assume. D'OH!
So it uses the security torx bits eh? Great...
Chubbs
@ArcticYukon
That's funny. You could have been in the posession of a perfectly reliable Tahoe this whole time.
Everybody should have a nice set of security bits on deck. Now you have a reason to purchase. No big deal, they have numerous app's
Shaw520
Going to install my Kappa's today,... and the reverse camera (hopefully) ..pics to follow.
Prorider17
I desperately needed new tires for my Tahoe. The Michelins were dry-rotted and wore unevenly. Going down the highway was nerve racking.. I found a guy online that had a 2017 Sierra with the 20" off-road wheels and Nitto Terra Grappler G2 tires. Scored a great deal and got them installed plus alignment today. Pretty happy with the look.
HiHoeSilver
Away!
Chicago
I like it! Is it 05 or 06?
Shaw520
Got it fixed,... think it was secondary positive cable on battery,...odd though because truck would start fine! ..which is usually the largest draw,.. go figure.?
TheAutumnWind
Thats good. Often weird problems with multiple issues are related to something like that grounds/battery/battery cables. I still end up chasing my tail most of the time before I check those though hah
MINIz guy
If all you want is protection, get a nice wax or sealant on the paint. I don't garage mine right now, so the protection is the only benefit.
I did the clay bar since my clear coat felt like sandpaper. Now it's really slick. I can still see plenty of swirls and light scratches since what I use doesn't contain any fillers/glaze, it's old school Danase Paint Sealant which you won't be able to find anymore.
Scottydoggs
NJ
i got that dual action buffer from HF. my paint was so not smooth. got some mothers compound, ran that over the whole truck, then hit it with mothers polish of some sort. its as smooth as a babys ass now. not a swirl to be seen and far less light scratches left.
Drewphil
