TheAutumnWind
Yep the Cognito rear kit for suvs comes with a 7” coil spring spacer. It bolts into the upper spring perch, basically just relocating the spring perch 7” lower.
Seems odd to run that much spacer. I guess it makes their kit a few bucks cheaper.
00'BlueSteel
Carolina
Yeah I didn’t really understand it either, but I wanted everything else that came in the rear kit. It’s like the only ones that actually comes with trailing arm relocation brackets to center the axle after lifting. And figured if I didn’t like the spacer I’d swap that out and maybe one of the guys in my area with half a lift kit will buy the spacers from me haha.
TheAutumnWind
Yeah im surprised. Generally they make some of the best kits.
Guess everyone has to make their product to a price point.
TheAutumnWind
Anyone ever clean their seatbelts? I realized that mine were supposed to be shale like the seats rather then brown...
Degreaser and pressure washer made a pretty big difference. You can see some 50/50 shots
20180309_144254.jpg 20180309_145745.jpg 20180309_145128.jpg 20180309_150717.jpg
TheAutumnWind
@Fosscore did it with a bucket.
im sure that would work. Soaking them and then scrubbing them? I just sprayed with degreaser and 5 minutes later hit em with the pressure washer. Didn't take much time at all.
Mine were probably way worse then most. The previous owner was female, dark complexioned, and in the fashion industry. I'm sure she hit up the makeup/lotion bucket a lot more then many people. Plus my interior is shale which is very light. Before and after was like night and day.
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
Got in it to take the kids to school this morning and KNEW the thing was going to give me a problem 'cause it was only 35* out (been going into REP mode when it's cold out), but figured I'd just let it idle until it's warm, then shut it off and try again... it's worked the other few days it's done it so why not, right?
No dice. Had to take the car instead. Then of course, this afternoon when going to pick them up, it cranked up and ran fine like nothing happened.
TPS looks like it's brand new. I'm about to pull the TB off and give it a good cleaning. Hopefully that will fix it, because at this point, I have no idea where I'm going to find that stupid APP sensor.
Chubbs
@ArcticYukon
So what's up? The engine goes into reduced power & you have a fault code for the accelerator pedal position sensor?
You said you don't know where to find a replacement part, what's the problem?
MINIz guy
Washed it again after the recent nor'easter. Hopefully the weather is nice from now on. The Tahoe definitely earned its keep this winter.
dszx13
Couple little things. Pulled the roof rack off. Picked up a set of gmc 20s for 125 bucks. Swapped my good tires over to them. Also have a set of 2c drop spindles waiting to go on.
Sent from my SM-G928V using Tapatalk
Great deal on the rims.
ArcticYukon
Dry Ridge, KY
@ArcticYukon
Yeah in a nutshell. Here's the kicker though.... only does it when it's cold out. Yesterday after the ouside temp got above 70, I drove it around all day long with no problem.
Gonna start working on that throttle body today though. Won't do anything to help the APP code, but it certainly won't hurt the problem.
Chubbs
@ArcticYukon
Eventually, the app will cease to function entirely. The ambient temp may contribute to the sensor operation at the present but 1 day it's going to quit at the worst possible time.
You are correct, spending time on the TB does nothing for the APP but I don't understand why you aren't repairing the problem. Is there not an auto parts store where you live? You could have ordered it on eBay or Amazon & had a new app sensor in your mailbox. I'm just not clear on that.
The app sensor went out on my truck, REP message, 1 fault code that I pulled for the app sensor. I bought a replacement sensor @ oreilly auto that night, along with a kit of security torx bits that have the indentation in the center -- removed the acc pedal, R&R the sensor, problem fixed.
My boss at work was trying to get me a replacement TB at first but I talked him out of that and my truck was parked on the lot next morning courtesy of pedal sensor per the DTC code.
MINIz guy
Clay bar'd and sealed the paint. It desperately needs a paint correction, but it's a daily so not sure how much more effort I'm going to put into it. The Pewter doesn't shine much more with a good sealant on it anyway.
Bombsquad85
Northern VA
Any of you guys here paint over chrome? I want to paint my wheels this week because the chrome is corroded and flaking and I don't like chrome.
wwiizz
