LRob
NGAneer
NWGA
I think I found the squeak in my right front... Upper strut mount. What have you guys tightened the center strut rod nut to? I'm going to try and tighten it in the truck.
NGAneer
NWGA
So... drew a line on top of the shock rod coming through the top of the strut mount and confirmed it spinned when I tried to tighten it. Tried a pass through 18mm socket and some pliers on the top of the strut with no luck. Ended up just pulsing it with my cordless impact to get it to budge until the socket stopped turning. We'll see if this gets rid of the squeak but I'm confident as the right side was significantly looser than the left side.
LRob
Im adding some dynamat to the rear cargo area where the rear HVAC is. Got a rattle in there over rough road and i think ive isolated it to the seat belt spool. Installed some dynamat around it and will see if that fixes.
ASG-MikeS
