Brett's 2004 Escalade 6.0 AWD build
Sevenevez
Arizona
Got the HVAC unit installed today that I had @ScottyBoy install LED’s in, came out great
The new head unit came in today too should have it in by the end of the month
Nice!
adventurenali92
Big Bear Lake, ca
Nice. Need white led corner bulbs now, take advantage of the white reflectors so it all matches.
Yea all nbs trucks alternate this way. Sierra, silvy, yukon, denali, caddy, tahoe all flash the same. Harness and bulbs all the same also.
Mine don’t alternate that I know of. The two rounds beside my DRL just flash as turn signals, but they flash together. They don’t alternate.
95escahoe
95escahoe
Got these GM door pins & bushings in yesterday, need to replace the ones on the driver door
95escahoe
95escahoe
what do they do?
What Tony said, a previous owner was in some type of accident and tweaked the door replaced the door awhile back found a clean one and realized the bushings/pins but couldn’t get the GM ones locally in time so put it back on and got these off EBay it opens and closes so much nicer now glad the hinges weren’t damaged
95escahoe
95escahoe
Installed some blue LED’s in the center console clock on the Escalade, was as simple as removing the old bulbs from the socket and twisting them back in, match the rest of the interior switches nicely the camera doesn’t do it justice
02EscaNate
Just stumbled across this thread and has me ready to dive into mine. Looks great with the all black
95escahoe
95escahoe
Thanks, you’ve got an 02 Escalade?
95escahoe
95escahoe
Yup. 02 That just rolled over 205k. Runs like new, just needs some TLC from being in Midwest winters for 18 yrs.
Not bad what color?
95escahoe
95escahoe
Bright white. Is one of the earlier ones before they switched to the Diamond metallic white
I’m not sure I’ve ever seen one, just the later white, that will be a nice truck to work with, start a build thread I’d love to see some pics not too many 02-06 Escalade’s on here
95escahoe
95escahoe
Installed the new cluster today, it’s a Platinum Escalade cluster with blue LED’s and needles, pics don’t do it justice and installed the rear HVAC control console had it all switched over to blue LED’s too
X-ray Nerd
