FS: OEM electric fan harness
SpinNice
Here it is! @ScottyBoy did an amazing job! Very clean, great service and communication! I can’t wait until the fans and my hptuners shows up! To be continued..
S
ScottyBoy
Shreveport, La
Got any more of them?
At the moment no I do not. I grab these EVERY time I come across them though, even if they have minor damage that is easily repaired. I WILL update this thread when I come across another harness that I can refurbish and post up for sale. It might be a week or two, or it might be several months. It all depends on how long it takes for more 05-06 trucks to show up in the yards around here.
01Konvict
Boats n Hoes
Raleigh/SML
Thanks for the update. My friend is building his 00 bagged ext cab and wants to do electric fans. Debating on original harness to extend or build one. The front electrical box has been relocated to the center console.
MCAT069
I snagged another harness today. So if you want it, or if anyone else wants this sucker, it's up for grabs. First come first serve. These things go FAST!!
Is this plug and play for a 04 2500 Suburban 8.1 4l85e?
MCAT069
Probably would need to have the pcm flashed for the fans to turn on.
I plan on getting the black bear tune; I already bought the AutoCal. I was hoping to find the correct fans for an 8.1 and do it all together.
S
ScottyBoy
Shreveport, La
I KNOW that the E-fan harness will work on a 6.0 but I'm unsure about the 8.1 liter engine. A custom tune will be needed regardless of what engine you have. I would email Blackbear performance, or send
@JennaBear a private message on here and ask.
And as being "plug and play", that depends on what your definition of plug and play is. If the 8.1 is like the 6.0, then no wire splices or soldering will be involved in installing the harness. 2 pins connect into the PCM, a power wire connects/bolts to the underhood fuse box power stud, a ground ring bolts on to the frame/chassis, and then the two fan plugs plug right up to the two fans.
MCAT069
I will message her now. They will be doing a custom tune for me as soon as I get the correct e fans. If this harness will work, then I'd like to purchase it from you as opposed to a vendor. I like to support fellow forum members whenever possible.
JennaBear
Resident Ninja
San Diego, CA
All depends on the fans being used. The 8.1L radiator is larger than the 6L.
Sent from my SM-G950U1 using Tapatalk
S
ScottyBoy
Shreveport, La
@JennaBear I have a question about the 8.1 engine. Does it use the same type of PCM as the 5.3 and 6.0 engines? What I'm basically asking is will an E-fan harness connect to the 8.1 engine wiring and fuse box just like it would on a 4.8/5.3/6.0 engine? You clarified that the radiator is physically larger, but now I'm wondering about the wiring.
JennaBear
Resident Ninja
San Diego, CA
We did not deal with a factory fan break out on our 8.1L so I can't give any advice on that.
S
ScottyBoy
Shreveport, La
I just found someone who installed E-fans on his 8.1 2500 Avalanche. Seems that the wiring IS the same as the 4.8/5.3/6.0 engine. The biggest hurdle is the much larger radiator. The guy in this thread modified his original fan shroud to fill the gap between the radiator and the 05+ dual electric fans. But the pictures are not longer working. Still worth a read...
http://chevyavalanchefanclub.com/cafcna/index.php/topic,103678.0.html
MCAT069
Thanks for the help everyone. The 07 classic 2500 came with an 8.1 and has an option for electronic fans from the factory. Part number is (brand) 4 seasons 76016 or brand TYC 622210. I think I can make those work since I'll have to modify the shroud anyway . @ScottyBoy I will buy your harness if it works with either one of the fans listed above.
S
ScottyBoy
Shreveport, La
Well, I cannot say for SURE that the 05-06 OEM Electric fan harness will work with the 07 8.1liter fans. Although, I did some digging on Rockauto, and the pictures they have of the plug on the fans look just like the 05+ truck fans. I also looked up a "Radiator cooling fan pigtail" and the same wiring harness pigtail comes up that is used on the 05+ electric fans. So it appears that the plugs ARE the same. The one and only concern I have is how much current do those huge fans draw? I honestly have no idea if the harness I have is capable or not of running those monstrous fans. I know it handles the E-fans for the 34" radiator just fine. I just don't want to assure you that it will be fine when I honestly don't know. If those big fans use the same amount of current as the 34" fans, then I would think it will be perfectly fine. But if they do indeed draw MORE current, then you may need to make a custom harness with 80 amp relays and 10 gauge wire.
dizhai
