bottomline2000
Check all of you plug wires and make sure they are fully seated. I had a plug wire pop off once and it caused a blinking check engine light.What do you mean your trims? Was that causing blinking cel?
Just saw your latest post..I would check your o2 sensors or it could be your cats clogging. U need a way to datalog the truck to see what the sensors are doing. I'd be curious to what your fuel trims are doing. If it's going lean it could be the fuel pump..
Ltft should be around 0 or 1..ideally less than 8. . If it's around 12 u have a problem. Plugged cats will run it up to 25..The computer is dumping fuel and trying to compensate for a problem.
