2002 tahoe lowered 2/3 sways really bad
LINTZ0718
2002 tahoe lowered on spindles and 3 inch rear lowering springs I work for Chevy and was gonna police take rear springs to stiffen it up ... I just ordered the djm trailing arm relocate kit and endlink kit and poly sway bar bushings.
Do you think it will take the rear sway out ? Should I get police tahoe springs?
Will i need adjustable rear pan bar too?
It has cai , flomaster ,bbk power plus 80mm tb long tube headers on next weekend
Just looking for sum input 981555D0-FC18-4834-AEEE-AB491F5C998E.jpegEEFA8530-91E5-439B-B7A3-4C977D3979EB.jpeg
BADRIDES
Looks good and lets see some more pics. I like the look of the lower spoiler on the front valance. I'm gonna add that to my 02 Tahoe soon.
LINTZ0718
LINTZ0718
Yea it’s from the 05
I got 243 heads saving for camshaft can’t wait to hear it with headers
Knope
NC
Just looking for sum input View attachment 189676View attachment 189677
I think those end-links and poly bushings will make a pretty big difference. Did you get a drop shock and a bracket?
a hellwig rear sway bar should help as well if you have springs only then they also sell a sway bar kit that will retrofit
BADRIDES
I have the Belltech sway bars on front and back with Street & Performance shocks.
08HoeCD
Did it sway before lowering or only since? If the sway is new, then something is wrong, such as broken end links, for example.
LINTZ0718
LINTZ0718
No it didn’t sway till I lowered it and now
It got cold i can lay on the ground and grab sway bar and move it. So that’s very bad imma install the bushings and djm kit I’m going to order bell tech shock but I put new shock on with the extenders BC8FFC0C-9888-4B22-83BB-A4959C0B806F.png
LINTZ0718
LINTZ0718
I hope so if not I will get sway bars I want suspension done so I can do motor work. What front endlinks do you run
Looks good.
BADRIDES
What's your measurements from ground to fenderlips?
ezstriper
if your shocks are not the right length or have lowered brackets will cause this, also I have done may lowered SUV's and trucks, the lowering springs are usually quite a bit stiffer than stock, so that should not be the issue.
LINTZ0718
LINTZ0718
What front endlink are y’all using with drop spindles
Knope
NC
When I was lowered, I used the Belltechs that came with Tony's 2/3 drop kit. I think I've changed to moog since taking the lowering kit off.
BADRIDES
Moog is the only way to go cause the Belltech's are junk
I am running Energy Suspension front endlinks and their poly bushings. On their website, in the PDF catalog under universal endlinks, they detail how to measure and order them. They need to be shorter it you're lowered in order to make the swaybar work correctly. Same in the rear, but that DJM kit you bought has the shortened rear ones. DJM also makes huge swaybars that work great, I'm running them front and rear. I highly recommend beefier swaybars, the stockers are weak. You can't go wrong with DJM and Energy Suspension.
TejasPitt
