BADRIDES
- Joined
- Dec 18, 2015
- Posts
- 1,731
- Reaction score
- 1,141
What's your measurements from ground to fenderlips?
Thank you. Gonna take sum better pic todayLooks good.
After my Belltechs's broke then I got MoogWhat front endlink are y’all using with drop spindles
Are they stock or shorterAfter my Belltechs's broke then I got Moog
Same length as the Belltech'sAre they stock or shorter
When I was lowered, I used the Belltechs that came with Tony's 2/3 drop kit. I think I've changed to moog since taking the lowering kit off.I hope so if not I will get sway bars I want suspension done so I can do motor work. What front endlinks do you run
Moog is the only way to go cause the Belltech's are junkWhen I was lowered, I used the Belltechs that came with Tony's 2/3 drop kit. I think I've changed to moog since taking the lowering kit off.
I am running Energy Suspension front endlinks and their poly bushings. On their website, in the PDF catalog under universal endlinks, they detail how to measure and order them. They need to be shorter it you're lowered in order to make the swaybar work correctly. Same in the rear, but that DJM kit you bought has the shortened rear ones. DJM also makes huge swaybars that work great, I'm running them front and rear. I highly recommend beefier swaybars, the stockers are weak. You can't go wrong with DJM and Energy Suspension.What front endlink are y’all using with drop spindles
