DallasTahoe
Got tired of inconsistent brakes so I got my nbs master cylinder and my simple brake proportioning valve set up and ready for my ABS delete installation tomorrow (crossing fingers)
DallasTahoe
Finished up my nbs master cylinder upgrade and my abs delete with no big issues and I didn’t even have to take the abs warning light bulb out of the dash, she stops pretty dam good even before doing a brake bleed, that’s next!
1BADI5
DMV
Installed this in the Yukon today.
I got all of the lines for the backup camera run, BT Mic installed; just need to get the camera mounted on the back of the truck (under the bumper)
The camera and streaming music via BT is an amazing function to have.......its going to be great for commuting
1BADI5
DMV
FYI - if you have a rear view mirror with the temp or auto dimming....... you can tap the harness under the A-pillar plastic. Its a green wire, I used a test light to verify the wire
The other 2 option are - 1) reverse lock out harness on the side of the transmission 2) tap the reverse bulb wiring at the back of the truck
jiggie
Got some new tires yesterday. Ditched the junk bridgstones. Went from the stock p255/70/16 to a LT265/70/17 all terrains in 10ply. Chose these cause well first they were affordable, 2nd they had good ratings on tire rack and they have the 3 peak mountain snow flake symbol on the side so ill be cdot compliant when we go to colorado in a few weeks.
Sent from my LG-M153 using Tapatalk
1BADI5
DMV
Well today was new hub assemblies and new brake pads....... easy work!
The pedal feeling with new pads is amazing! I'm really impressed with the Duralast Gold pads..... I normally buy either Hawk or EBC
99YukonSLT
Ohio
Gonna pull my yukon into work overnight friday to let it sit and warm up so I can come in saturday and change the oil, trans fluid, remount my fogs, and figure out which ABS sensor or hub is bad causing the ABS to kick in at slow speeds. Probably throw my tow hooks back on and give it a good once over.
jiggie
Decided to get some new wheels today. Wife picked out the wheels. Didn't want chrome or super flashy wheels. Just something classy looking. Went 22s with 305/40 tires so i still have good sidewall and so it would fit in the garage. Did 24s first and the roof rack hit the garage door lol.
1BADI5
DMV
Got the 2" blocks in so the lift is complete (torsion bar crank & RC UCAs)
Tomorrow is Proforged inner/outer tie rods, Proforged billet sleeves and MOOG K100335 2* adjustable cam bolts
Then off to get an alignment at Extra Mile Performance, in Odenton, MD
1BADI5
DMV
Inner/outer ties and sleeves done............. yup, needs the pitman arm and idler arm.
**** it........ new pitman, Idler arm and idler arm bracket. I'm doing it all and done.
Kelsda
New Jersey
Changed out right side washer nozzle picked up a few at the local bone yard no charge
jiggie
After a week decided these are not the look were going for. Tire shop is letting us return them and might swap wheels for some oe reps like this
wwiizz
