inmypassatlife
The point was that if someone dings the vinyl I can just redo that panel if it's bad, but a chip in paint is a more costly issue, not to mention downtime and color matching etc
drowssap
Colorado
Well it was you that said you don't want to be worrying about dings in a truck that old in the same breath you said you were doing a wrap. So yeah. It needed to be said. And where did you mention you had a car refinishing background or custom background? I must have missed that captain obvious post. I did see the part about this topic getting off track though, so I guess this must be your build thread? LMAO. :flamingdevil:
This was flippin hilarious!
05Single
afraid of the dark
Not having to blend in panels with wrap is much more betterer:D
I wanna wrap the top half of my tahoe for a two tone look. I think silver or gunmetal would be clean against the indigo blue.
05Single
afraid of the dark
Ok so I was givin the wrong info from my brother. He thought I meant something else, and we were both confused. Anyway I was able to get a chance to look at his. He has the trim pieces for the captains chairs but they're different and will not fit the bench.
So I'm assuming esky and nali have the trim pieces stock and are also interchangeable.
Case closed.
His
His next to mine
Pretty certain I'm the only one that cared about this. Doesn't matter, my ocd has calmed down because of this.
05Single
afraid of the dark
His is a dvd player form like 2003 lol. Mine is an amp. No rear entertainment for me :(
Red and white is audio. See yellow it's video.
Are you sure it's not from 1993? Mines in my hu but I've never even played a DVD.
kwOH
Banned
Case closed.
His
His next to mine
That explains everything, my 05 had captains chairs.
TheAutumnWind
Got 4600s installed in the front with resistors. No warnings yet...
Also installed my steering damper finally!
The escalade feels great!
******* found some torn boots on my uca ball joint and on my outer tie rod end though which pisses me off because they only have 10k miles on them and this escalade is stock ride height! ********. Both acdelco advantage parts. I learned my lesson... Moog problem solver or pro series Delco only.
What brand are the tie rod ends?
wwiizz
