I had a prototype set of cryo-tempered Power Slot rotors on my S10 since around 2004. Paired exclusively and always with Hawk HPS pads, that was the most incredible set of direct-replacement rotors and pads I've ever known. They stopped smoothly, quickly and reliably no matter what- temperature, frequency- it didn't matter. After about 12 years, 70,000+ miles and one change of pads, the rotors barely had a lip around the edge where it had worn over time.
I bought these cryo-tempered slotted Power Stop (or Stop Tech) rotors thinking they were the same thing. They're wearing faster than the pads. I got Hawk pads again but their LTS version since it's a Tahoe. I like the look of the slots, but they dust like crazy and I'd rather have smooth brakes than be concerned with some flair.
Thanks for the part numbers and input!
Tiki
I used the "OE Performance" upgrade (came branded GM) on my Tahoe which are the Raybestos R-300 line. We cycle them pretty good and have been happy so far. For my requirements, I wanted to stay away from anything that is drilled as that's where is saw documented issues. The fact that GM was cool with them was reassuring.
PG01
Up here to the right
Those were from GM’s China division GENERAR MOTORS
Burnswil
Tried to diagnose an oil leak and found a coolant leak as well :(
Probably better than the exhaust leak I fear I have. Took it to the dealership for inspection and they said I need to replace the manifold. I thought BS. I then was like man my throttle seems sluggish. Pulled it in the garage before leaving for the holidays and it seemed to smell. Probably either a hole in the manifold or the gasket. Can't tell if it's noisier or not.
Drok
Cold place in the north
That happend to my 05 and it was manifold bolt heads rusting and breaking off. Which caused them to slightly separate from the block especially in the hot and cold weather.
992dr
Eastern N.C.
Aww man. Atleast you caught it now rather the find out the hard way..
True very true
Man, that stinks. BUT, now would be a good time to upgrade to some nice LTs ;)
It seems to be a common problem.
I'm lookin at getting some header studs to replace mine. I'm just dreading and hoping they are all intact.
Burnswil
I've already looked at lt's. Thinking about speed engineering
93blkongreenpro
Rear tires rubbing the inner fender in highway bumps. Time for rear shocks. I have brand new zw7 shocks in storage. Now that I have researched and find that a 8" or so extension is the key to getting the top nut off, I guess when i have a few hrs, I know what I am doing. And my tire shop says I need a passenger side upper a-arm. I will go Moog or oem this time. When it gets warner, driver side hub and both lower control arms.
NGAneer
NWGA
Have you flipped your upper shock bolts?
08HoeCD
Resisted the urge to spend money on $hit I wasn't sure I wanted, really don't need and would probably get bored of anyway. I'm calling that a win.
Fosscore
Me too. Bought a new mower with a discount from some gift cards and the wife a few things on sale.
Searched over much stuff, but did not pull the trigger either. Still have some gift cards though....hmmm
NGAneer
NWGA
New set of autolites (under $2 a plug after the rebate), greased rear sway bar links
Hodmjstone
