Costal_Cat
- Joined
- Mar 31, 2017
- Posts
- 85
- Reaction score
- 84
First post but I should thank the forum for all the info to date. I to have the typical cracked dash and me to not wanting to spend $500-$1200 decided to fix it myself. I did things a little different than most folks thanks to this youtube video
One tool that was used in this video is a Hot Staple Gun Kit for Plastic Repair which is a pretty unusual device. You can find it here for under $100
https://www.amazon.com/Astro-7600-Staple-Plastic-Repair/dp/B0096PGOOQ
This gun melt plastic staples into the dash so that when it cools, you have some metal reinforcement around the crack. Here is a couple of pictures of my repair
After putting in a bunch of these staples I then used a plastic epoxy for additional reinforcement over the staples.
Here is what they looked like afterward.
This is over the driver dash pod
and this is the passenger airbag
I also fixed and reinforced some additional cracks around mounting points. Used rubber washers when reinstalling. Added some foam under the dash pod and around the center speaker for additional support. I only have a couple of days driving now but it feels very solid and in putting it back in there was enough flex to get it back in and everything held fine.....
On the plus side since I had the trim out I polished all the wood with some plastic headlight restorer and that got rid of a lot of the scratches.
I have a couple of 5 hour drives coming up so I will post if this fails....
job and it is under $150 with the plastic staple gun and supplies. If you get the power rachet it is an additional $150.
