HID reverse lights
zach2011
Platinum Member
Where did you install these? It looks like all the wires and ballasts would get in the way of putting the tail light back in place.
tx07tahoe
tx07tahoe
Houston,Tx
If you pull the tail light assemble out you can mount them behind the bumper.
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
Sounds good enough if they took only 3 seconds. But wait. Were yours just bulbs or did they come with a ballast and everything to install?
Yes, I mounted my ballasts to the frame behind the bumper.
The ballasts stayed mounted to the vehicle. If the housing has to be removed it is a matter of disconnecting the HID bulb wiring at the same time you disconnect the tail light harness. :Handshake:
zach2011
Platinum Member
Fair enough. I might have to do this on my own, my dad's getting less optimistic about helping me mod my truck since it depreciates the value. I guess he doesn't remember that I have all the original parts for when I get ready to trade in.
tx07tahoe
tx07tahoe
Houston,Tx
Ya I got a box full of spare parts for the Hoe and Silvy in a storage garage.
zach2011
Platinum Member
They're H11's, yes. They said they mounted the ballasts under the bumper, and I imagine the bulbs themselves fit just fine into the light.
zach2011
Platinum Member
Yeah but how is it hooked up to get power?
I'm sure it's just like regular HID setups. The ballast connects to the tail light harness on one end and the HID bulb on the other end. Someone correct me if I'm wrong.
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
The bulbs that I received would not sit flush into the housing until one of the tabs had been removed from the bulb itself (I figured it would be smarter to do this to the bulb instead of the housing).
williajj
Minnesota
Yes, one of the tabs must be broken off. It's not plug and play however, you have to splice into the reverse light wires. I siliconed mine up pretty good after the install to avoid any condensation issues.
92__silverado
Has anyone else done this, or have some pictures of the install? This seems like a reall worthwhile mod, especially if you can put it on a switch so it will come on with reverse or say when you are working around back hooking up a trailer or just need a little extra light behind your rig.
Modded
That Guy
Does not depreciate your truck at all, if anything it increases the value.
The only thing is that you may not get back what was put into the truck (maybe only $2k if you put $3200 or something), but just don't overdo it and you will be fine.
BC Lightning
Yes and no, most dealerships go with market value on trade in and give you nothing for mods done to your vehicle, but they will turn around and charge more for having stuff done to it
best way to get your money back is to sell it yourself, or put 100% back to stock and sell your mods
Modded
That Guy
Oh, well there is not trade ins over here, private sell onlly! :D
zach2011
Platinum Member
Yeah whenever I trade it in one day, I'll put it back to stock. I checked and the only stock things I don't have are the Tahoe tail light harnesses and the regular bumper pad.
Then I'll just sell all the stuff I bought for it, if it's no use to me, and get something out of it. To be honest, I haven't put much into my mods. Anything Denali on it, I got for free.
scottd
