How bad is it Doc?
Jeri99
I have this weird leak coming from tubing around the master cylinder...maybe some pics can better expain: IMG_2292.JPG IMG_2293.JPG
Anyone have an idea what kind of leak this is and how I can go about fixing it? Thanks in advance
M1Gunner
Gainesville, Fl
Powers steering fluid from the hydraboost system that is in place of the vacuum brake booster. Honestly that "leak" I would not even think twice about it. It's only residue and very minimal residue at that. If you were to clean that off, it would more than likely take a good amount of time to be noticeable again.
If it were my truck, I'd double check the power steering fluid but youre more than likely still sittin topped off and let that ride.
bottomline2000
Dallas, TX
Thank a lot guys for the info I'll look into it for sure
If the area below where the master cylinder meets the hydro boost is dry you can just replace the hose. My hose was covered in fluid so i did both because i couldn't tell where it was comimg from. My brakes worked better afterwards but I had a bad leak.
Steve A
Central AR
Kinda hard to tell from the picture but my vote is the hose end is leaking a little. I'd try a new hose first.
J
Jeri99
Fro
Just when I thought this would be a simple fix...I noticed something weird about my brakes this evening after my ride home from work. Mind you the car is in park when I noticed this but Theres a slight pressure releasing sound accompanied with“squishy” feeling on the brake petal when press down on my brakes while the car was in park. When braking while driving around the car stops without issue. Does this sound like a symptom of the seepage/leak that we’re talking about here? I’ll post a video tomorrow of the sound.
J
Jeri99
Ok guys a have a video... any input is greatly appreciated...I’m going to follow the advice provided above but I wanted to see if there are any thoughts on what you hear on the video
Make sure your power steering fluid level is good. That sound could be air in the system from the level being low. When driving around, the RPMs are up and the PS pump is pumping faster so it can overcome the symptoms of low PS fluid that you'd normally feel. I wouldn't worry a whole lot about that hose unless you can see actual wetness and or dripping. Follow the hose down to it's lowest point and see if there's any evidence of fluid drips. If not, you don't have to make it a priority. At least be sure your PS fluid level is good, though.
M1Gunner
Gainesville, Fl
If your power steering fluid level was low then you'd hear the pump itself screaming before any hissing. Background noise seems pretty quiet. Is the truck running? You may just be bleeding out the accumulator.
J
Jeri99
I'll check the power steering fluid just in case. The car is off in the video. Newbie/Lazy question....where/how do I check the power steering fluid?
M1Gunner
Gainesville, Fl
Drivers side, look for a cap below the alternator.
With the vehicle off, you're bleeding the air pressure from hydraboost's accumulator.
In that case, it's the accumulator as Jason mentioned. It's that canister on the upper left side of the booster. It holds some pressure so you can maintain braking assistance (boost) even if the engine isn't running. More simply, it lets you have brakes so you can stop the vehicle should the engine die on you. You'll get a few good pumps of assisted brake pressure before the pedal becomes hard to press, but hopefully you'll have the truck stopped by then.
Skiroy56
