305/55/20 Tire and Level
T
tomsquad418
Regardless I'm doing 2.5/1 level kit...want to rub stock rims and would prefer not to run a wheel spacer
NGAneer
NWGA
Its not, 1" rear spacer is lifting the truck and thereby clearing the upper shock bolt and stopping the rubbing of the upper plastics...... but i may be wrong.....maybe he put a 1" rear wheel spacer.... lets ask him.... @NGAneer ......esplain plse
Yes. 1" rear coil spacer, not wheel spacer. When the truck would articulate over a large bump (think 90* turn into a steep driveway), the top of the tire leans in towards the body and would rub the liner covering the shock bolt. I know the spacer made a difference in the frequency of the rub because of the greater articulation needed to make it rub. Flipping the shock bolt reduces the severity because it took away the high point of the bolt threads being just behind the liner. Instead of 1-1.5 inches of nut and bolt thread stl king out, there's just 0.5 inch of bolt head sticking out.
PG01
Up here to the right
Tanks nga ...... ;)
T
tomsquad418
Now I'm debating between a 285/60 and 305/55
Decisions decisions
T
tomsquad418
I was just about to ask if a 295/60/20 would fit on the new body style with a 2.5/1".
Really want something thats around 33.5+ x 12" wide
Trying to keep a tame look and aggressive stance with stock rims
NGAneer
NWGA
I'm looking for something similar. The 305s are great, especially on width but now that I'm basically at 3/1, it needs more height.
T
tomsquad418
All the shops I talk to keep telling me they won't work well on stock rims or will billow over or I'll need aftermarket rims or spacers..however it seems people with ford f150s or Silverado all have run 305s on stickers. I don't want want anything that looks like pizza cutters
T
tomsquad418
No one will let me test fit tires either so im stuck on sizing
NGAneer
NWGA
305 will work on stocks IMO. Plenty of guys running them and I've had them on mine for 2+ years.
T
tomsquad418
Every shop I have spoken to believesa 295/60 is too big on a 15+ with a leveling kit. I believe one guy ran toyo open country mts in that size with the RC 3.5. Just need to pick between a 305 or a 285/ 60 I guess...
DWSmoot
Charleston, SC
Just installed 305/45r22...32.8"
305/55r20 is 33.2" so .4" difference. I think it will fit. Worst case zip tie the liner back a tad...
Clearance on 2" RC level
T
tomsquad418
Do
So I saw a Tahoe identical to mine today running 275/65/20s. I can't imagine he doesn't scrub. That's about 34" inches tall and a little more narrow than stock but looked like he was running it with stock height. Still had rake in the front. Makes me feel like I could get away with a 295/60/20. Thoughts?
NGAneer
NWGA
Do
That would have to rub
T
tomsquad418
Which tire size would get the worst mileage? 285/60/20, 295/60/20, 305/55/20?
Ruben7475
badass wheels man those are the ones im looking at for my yukon but in 18s
T
tomsquad418
Stay tuned - I'll try to snap a couple pics
Finally got around to taking a few pics. Mine is on the left with stock suspension and a ppv valence and the one on the right has what appears to be stock suspension and 275/65/20...it looks meatier in person.
HeavyHoe03
