New battery/starter/alternator cable part#s?
Charlie207
LFOD, New Hampshire
I'm looking to put in an order for some new power cables under the hood, and was hoping someone had already done the same thing, along with listing all the part numbers.
I've been searching around, but not having total luck, so if anyone knows the info, that'd be great. Adding that info to a sticky here, or in the "Tech Info" sub-forum would be sweet.
Try these.........
Negative Battery Cable
22846471
GM
Description:
Silverado, sierra. 4.8l, 5.3l, 6.0l, 6.2l. Yukon XL, Suburban. Tahoe, Yukon, Escalade. Main battery. Without wiring provision. Avalanche, Escalade EXT. All. Escalade ESV. 1/2 ton. Negative. Powers vital electrical components by transferring electrical curr ...
Positive Battery Cable
22850357
GM
Description:
Without 6.6L diesel. 6.0L, main battery, without code: 9l4. Silverado, sierra. 6.0l. Yukon XL, Suburban. All. Exc.12 Volt Power Provisions. Positive. Primary. Without wire provisions. Escalade ESV. Powers vital electrical components by transferring electri ...
Starter Solenoid Cable
22790285
GM
Description:
Tahoe, Yukon, Escalade. Main battery. All. Avalanche, Escalade EXT. Without wiring provision. Silverado, sierra. 4.3l. Exc.12 Volt Power Provisions. Positive. Main Cable. , starter solenoid. Durable insulation helps protect from moisture and contaminants This GM Genuine Part is designed, engineered, and tested to rigorous standards and is backed by General Motors
Alternator Battery Jumper Cable
20943125
GM
Description:
, jumper. This GM Genuine Part is designed, engineered, and tested to rigorous standards and is backed by General Motors
Charlie207
Charlie207
LFOD, New Hampshire
Try these.........
22846471
View attachment 480873GM
Description:
22850357
View attachment 480874GM
Description:
22790285
View attachment 480875GM
Description:
20943125
View attachment 480876GM
Description:
Thank you!
Capybarbro
