Fosscore
- Joined
- Apr 16, 2014
- Posts
- 10,888
- Reaction score
- 19,869
Congrats man. Nice work. My brother has a few years to go for retirement, but I know he gunning for it.
lol
After I finish the interior...this is the next thing on my list
View attachment 179777 View attachment 179778
It even has that rare engine cover still
I didn't even know they were that rare...the engine bay is spotless
OK correction: the Hoe is an 01. The esky is an 02?
All NBS Escalade's have the 3pc cover the 02 is the only year it has the Caddy logo on it the other years just say Vortec 6000
I hope you didn't do that Pergo crap, that fake hardwood flooring. That stuff is garbage Imo.I was unaware of that... I just need to find a place to swap out engines without going broke, just dropped lots of $$$ on new hardwood floors for the house
Correct, Esky is an 02...Hoe is an 01
The mileage doesn't really matter to me as long as I stay on top of changing all the fluids. The only problem I'm having now is how to remove and swap both steering wheels
An auto parts store should have a steering wheel puller for rent. To get the airbag off you need to have the battery disconnected for at least 10 minutes to be safe, then stick a screwdriver or something similar in the two holes in the back of the wheel and push from the inside of the wheel out. It should come off fairly easy. Then the yellow plug on the airbag needs to be removed, pull the little tab off, then the full plug. Then the red wires that run into the hole on the top left of the center needs to be turned clockwise on the little white plastic part and it should come out. Then you remove the big nut on the steering shaft then use the puller to get it off.
