2011 avalanche dropped 2/4
Rollout12183
Here's my avalanche dropped 2/4 with belltech kit
NathanJax
Vacation Nathan
Jax, Fl
Looks good
NORCAL SS
SUV SUSPENSION GURU
rear will start riding harsh give it few weeks. Look up the free travel mod along with the endlinks/bumpstops i offer and yoru set.
Looks good though
Rollout12183
Rollout12183
Looks good though
I did the free travel mod and I got the bump stops from you I still need to buy the sway bar links from you.
chilleblanco36
Need more info on this norcal drop. Your ride looks good. I want mine lowered, but I would still want the rake. From time to time I will tow and take family trips.
Sent from my SAMSUNG-SM-G935A using Tapatalk
NORCAL SS
SUV SUSPENSION GURU
I can set you up with the kit. Done and sold many here including those posted above
here is the kit
http://tbssowners.com/store/index.php?act=viewProd&productId=87
and if your towing i would do the free travel mod along with endlinks/bumpstops option from my site and i can set up a helper bag set up and you can tow perfectly fine
chilleblanco36
here is the kit
Ok. Trying to decide if I want to lower it on factory 20's or wait til I get some escalade 22's. My wheels are perfect and tires are almost new.
NORCAL SS
SUV SUSPENSION GURU
With my fender well mod and rear trim liner there's no rubbing
NORCAL SS
SUV SUSPENSION GURU
2x4 on fenderwell and move tire so rolls the inner fender back which in turn makes you clear taller tires without issues. 2x4 gets sucked into the inside which inturn moves not just outisde but entire fender back to clear 305 35 24s. Also i use this on the 07 to 17 gm trucks when putting 35s on the front and instead of cutting the fender up it clears it by a hair.
Conedaddy
