kbuskill
NE. FL.
Man i think the tuner is causing a code setting my engine light off (u0073) i unplugged it and it hasnt come back on when i drove home..:confused: the tune still seems to work even with the tuner unplugged so thats good i guess
Not sure if this has anything to do with it or not but:
U0073 CHEVROLET Control Module Communication Bus OFF
https://www.autocodes.com/u0073_chevrolet.html
Kenny D
Crosby, Tx
Is it required to stay plugged in to run the current tune? My Diablo just flashes the ECM and then unplug and store in console.
M3kanic
With any gmt900 (our trucks) you need two tunes. 1 ecm and 1 tcm. But no they don't need to stay plugged in. You are reprogramming the ecm and tcm.
M3kanic
Hopefully the last time im doing brakes on this for a while.
Here recently I've done oil change, replaced weatherstripping, blower motor and resistor for front fan and will be doing brake pads and hubs here soon.
DaRosa218
The Dude abides
Modesto, California
The joys of being lowered.... Snapped passenger cv-axle and can't replace it until I get new upper control arms. Having 2" lowering spindles, it requires us 4wd to cut the upper ball-joint bolt flush with the nut making it impossible to ever take off and back on again.... End of Rant:893Chainsaw-Smilie-:flame:
NjA4207
