ABS LIGHT ON
JonnyTahoe
JonnyTahoe
Minneapolis
Thanks for the suggestions. I did get a brake switch code so I picked one up and will see if that does anything.
JonnyTahoe
JonnyTahoe
Minneapolis
I had that happen a few years ago the Hub Wire was worn from rubbing on the suspension.
rndsommer
Had same issue ebcm was the problem on my 01 tahoe. Very common problem on 00-06 trucks.
How do you pull/find the code for abs?
Autozone and O'Reilly should have a scan tool that'll read the ABS module and they should read it for free. Most any decent mechanic shop should have a capable scan tool to read it, but they'll most likely charge you a diagnostic fee.
CdnDenali
thanks
veteran111
