Thinking of buying 94 Tahoe
weatherfordjacey
So I found a guy on Craigslist selling a 94 Tahoe for 2500 I test drove it today I love it but the thing is the steering is really loose I'm mechanically inclined I'm just wondering if it's worth buying and fixing or is fixing it gonna cost me what I payed for it so help me decide if I should get it or not
Sent from my SAMSUNG-SM-J120AZ using Tapatalk
mtl111
Arkansas
Loose steering is unfortunately pretty common in these trucks after racking up 100k + miles. Worse case scenario, it would need a steering sector, pitman arm, idler arm, all 4 tie rods. I would check the ball joints and control arm bushings as well.
If you have the tools needed for the job, its not difficult. I would recommend Moog parts, in my opinion they are the best.
Is it worth it? Well $2500 is a damn good price as long as the rest of the truck is in decent shape. Check around for prices to get an idea of what everything would cost if it is that "worse case scenario" .
Sent from my SAMSUNG-SM-G930A using Tapatalk
W
weatherfordjacey
The only other bad part about the truck is the interior and no a/c and drivers window won't go down
mtl111
Arkansas
Sounds about right for a $2500 truck! Lol! Alot of good interior parts can be found at salvage yards. The a/c probably needs a compressor or possibly just a leak. Switch or motor for the window. If this is going to be a project truck and you can take your time with it, it doesn't sound any worse than the issues mine had when i bought it! And i paid damn near twice as much!
W
weatherfordjacey
Here's what it looks like the paint is rino lining
scotto0609
Sounds a little high depends on miles and rust /rot along with any new parts receipts. before you know it your in the truck for 4k and it s only worth the original 2500. good luck
RicanGM
Fountain, Colorado
Here in Colorado if the 4 wheel drive works good, low miles, no rust , no accidents that price will be about right.
scotto0609
I agree , there is a lot of room on price depends on where you are!
W
weatherfordjacey
It's got 200k miles and I'm in Texas I'm gonna talk him down some
east302
Mississippi
Any leaks--oil pan, rear differential, rear main seal?
08HoeCD
Hobby/project vehicle or daily driver?
Me....I wouldn't touch it for a dollar over $1,500
W
weatherfordjacey
It looked like the valve covers leaked a little other than that it looked good
east302
Mississippi
Not a deal breaker, then. Any idea if the engine or transmission have been rebuilt?
The A/C could be your larger expense. Did they still use R12 in 94 or has it been converted?
Even if you had to replace the steering gear, you could probably do the whole front end for no more than $500 in parts.
Edit: Is it a Chevrolet Blazer? The GMC grill looks like a 90-93, they switched them for 94 to a body colored surround. With that and the hood, wonder if it was wrecked?
Contend997
Frostproof , fl
Sounds about right. Looks like a good deal to me. If you have engine problems you can ls3 swap it or keep it stock but the ls swap is worth the money. Will pay for itself in gas savings in a year. Nice truck I would buy it. The steering is a easy thing to fix the window is easy even If you have to buy parts new it won't cost you alot to get fixed
bigT63
I had a 94 Silverado... I miss that truck... anyway I spent countless $$$$$ trying to get the A/C right. I ended up changing the low/high pressure switch out as a last effort and it worked like a champ. 3-5$ part at Napa/AZ/O'Reilys.
RED TAHOE LS
Rossville, Georgia USA
thing is the steering is really loose. That could be an expensive repair and that could put you over market value. JMHO and good luck.
David g......:)
LBDelaney
Texes?
Then it should be rust free that alone is worth it..
I have two 97 sC1500 one with 250k and another with 295k
One is rusted out but rebuilt motor and trans and the 295k still all OE not touched some rust but not bad.. would give that just for a rust free body.
Back N Black
Houma, LA
Doesn't look bad, and it's not a terrible price. First rule of buying any vehicle, new OR used, talk them down, they will always take less. Sounds like you could fix the issues the truck has, and make a pretty truck out of it. Go for it!
veteran111
