juan84
Mounds view MN
Seafoamed it. Changed the oil and added the catch can. Also put on the window visors.
What catch can did u go with ? Link??
sent from galaxy s6
Drok
Cold place in the north
M3kanic
It took me forever to decide what brakes I wanted and now that I have they are on back order. Hopefully the last rotor gets shipped out on Friday. I ended up going with stoptech cryo slotted rotors and hawk hps pads. Now if my wife would stop warping the rotors I'll be good.
M3kanic
The inlet is a small 1 in tube with a baffle at the bottom filled with what looks like red scotch bright pad.
Drok
Agreed to above.
I should take mine apart sometime im sure it needs a cleaning after all the year of using it haha.. hopefully i can get it apart easily..
NGAneer
NWGA
Show of hands... who has a tank that's empty but put a stainless scrubber in there? I did and just want to check on other results.
PG01
Up here to the right
Not my video but the is what it is.
good vid....thanks....a tad fruity, but informative nonetheless... mine should be here today or Thursday.....
^^this....
PG01
finally got my fuse holders in .over kill never did anything harm lc2i now works[emoji3] [emoji3] lol
sent from galaxy s6
Do you think the female connectors will eventually get loose that way? I hooked up to ignition the same way for power to my plow but when i was doing it i came across the bcm "plug" with short wire leads that you can splice and solder....cant find it now of course, i had a part # and all.....:smh:
juan84
Mounds view MN
Yea I have it saved in my eBay like 25 for it. If they start coming loose I'll buy the conector
sent from galaxy s6
juan84
Mounds view MN
Now to figure out the feed back noise !! Sounds good even with truck running until I close the door . I've read about a wire that can be cut by the factory amp. I need to find out if I have the lux or basic most likely lux bc it's a denali
sent from galaxy s6
ASG-MikeS
