Dropped 2016 Tahoe LTZ 2WD question
16blkltz
Is the rear axle shifted slightly to the right (towards passenger side of Tahoe)? It looks like my left rear wheel/tire is slightly inside fender while my right rear wheel/tire is slightly out.
I have belltech 3.5-4" rear springs.
Installed 5/8 heater hose mod (removed upper spring spacer) with shorter autoride sensor rods.
I did not do the free travel mod because suspension ride is fine for me and my family.
24x9.5 wheels
295 35 24 tires
2016YUKONSLT
Is there a panhard rod on these vehicles that can be adjusted?
16blkltz
16blkltz
The OEM as far as I know can't be adjusted...which I just realized is the reason I'm seeing this axle shift. I tried looking for 2015-2016 Tahoe/Yukon adjustable panhard bars, but couldn't find any.
16blkltz
16blkltz
Check this link on tbssowners.com
NorcalSS is the vendor and member on here. http://tbssowners.com/store/index.php?act=viewCat&catId=58
Here are a few kits for the 15+ depending on what you have on your truck that might answer your question or point you in the right direction. Email or PM him for additional questions. @16blkltz
Thank you. I actually purchased parts from Tony recently. I'll try to PM him later today. I went to his website and the closest thing I could find was an adjustable Spohn panhard bar for 2007-2014 GM SUV: http://tbssowners.com/store/index.php?act=viewProd&productId=163
gat0r
DFW
i'm lowered about 2" & my offset is barely visible.
spohn doesnt have anything for the 15+ yet.
i emailed them back in Oct & they said they were working on parts.
interested to see what options Tony has for ya.
especially since i want to go lower @ some point
BADRIDES
24x9.5 wheels
295 35 24 tires
Why do you spend all that money on a kit and have to do a heater hose mod?
NORCAL SS
SUV SUSPENSION GURU
because 15 up the upper insulator is very thick and by doing my mod you get more drop. this is why i can get my kit to go from 2.5 to 4.75 inches on a autoride truck. ALso by doing this you dont have to adjust the autoride links shorter which makes less air in them and hurts ride
NORCAL SS
SUV SUSPENSION GURU
yes i do installs. If you see my 16 escalade i have my 3/6 kit on it
NORCAL SS
SUV SUSPENSION GURU
you have to take spring out again. I woudl just do it while springs are out and rear end hanging down so you have more space
j_jerry79
