New system plans for Christmas
xX Mavr1ck Xx
Middle Tennessee
:party33:Going to upgrade to a new system after Christmas! Here is what I am planning on buying for the upgrade.
3 Kicker CompVR 12" 4-ohm DVC, will equal to 1200 watt RMS
http://cgi.ebay.com/ebaymotors/KICK...70413032613QQptZCarQ5fSubwoofersQ5fEnclosures
1 Kenwood Excelon X1200M, 1200 Watt at 2-ohms x 1
http://cgi.ebay.com/NEW-KENWOOD-EXC...ewItemQQptZCar_Amplifiers?hash=item45ef335ed6
**Never had Kenwood anything, but this looks like a good amp for what I need. Anybody got a problem with Kenwood?? Let me know please.
I plan to build my own box, it will probably be ported if its not too hard to do. I've already got 4 gauge amp wires ready from my previous setup, and I'll probably do the big 3 upgrade with the new system.
The subs and amp will equal up to roughly $430.00, I'll need some new speaker wires, and for the big 3, I'm not sure how much 0 gauge wire is going to cost me or how much I'll need. Hoping to spend about $500.00-550.00 total cost.
What do you guys think?
drowndindreams
Unknown
if your amp is pushing 1200 at 1 channel, and is a one channel amp, then thats a no go. you need a 3 channel amp to push 3 subs, or 1 amp for each sub 1 channel means that there is only one pair of + and - to run to the sub
xX Mavr1ck Xx
xX Mavr1ck Xx
Middle Tennessee
Yeah I believe it is. So do you think itll work good? I think the big 3 will help with the added power, do you think that everything will be good running it off my battery alone? Should I get a cap too?
drowndindreams
Unknown
if youre going to run anything above 1000 watts rms than a high output alternator is recommended. adding another battery is also an option. either use 4 gauge wiring or smaller (the smaller the numbers go the thicker the wire). big three would highly help.
and a capacitor is a must. they usually are used with every 1000 watts, 1000 watts = 1 farad cap, 2000 watts = 2 farad cap, etc.
TnTahoe
TN
the setup will work, but i wouldnt waste my time with caps, you will be fine with just the amp and the subs,
blueflamed03
Oklahoma
agree. The 2.67 ohm load will be fine and wire up like so.
xX Mavr1ck Xx
xX Mavr1ck Xx
Middle Tennessee
Cool. thanks for the feedback guys. I'll probably be doing the big 3 this weekend if i have time. I'll probably pick up some 0 gauge wires at a local audio shop, how many feet do you guys think ill need,bout 10 ft.?
drowndindreams
Unknown
more than that, if your battery is on the right side of the hood near the coolant tank, id say 12 feet, if its on the left, less than that. and another 2 or 3 feet for a ground
blueflamed03
Oklahoma
20', then can use some for Big 3, and have some to spair. Most amp kits come with 15 to 20'.
xX Mavr1ck Xx
xX Mavr1ck Xx
Middle Tennessee
I've been running numbers on the box design Im trying to do, and still having trouble: The specs for one sub is 2.25 ft cubed so the total will be 6.75 ft cubed. So I was thinking of a box that will be "about" H=15, W=48, L= 21. Just something i punched in, that total is 7.08 ft cubed. That is for a sealed box, but I'd to port this box. I just dont know how to do a port(s) for 3 subs. Should I seperate the subs into chambers and do an individual port for each chamber? Or Just do one long port for all 3? Any help with this would be great! thanks for reading.
EDIT: The specs for the subs are for a ported, not sealed.
blueflamed03
Oklahoma
do all three in seperate chambers, then that will may the box smaller, but aim for about 2.0 per chamber then port.
xX Mavr1ck Xx
xX Mavr1ck Xx
Middle Tennessee
sounds like a plan, ill get some measurments when i get off work tonight, cant wait to start working on this! I bought a 4x8 piece of MDF and it cost 27.00! I that was a little much but i dont really know. thanks for the advice blueflamed
xX Mavr1ck Xx
xX Mavr1ck Xx
Middle Tennessee
BIG 3 Question
Okay, so I'm doing the big 3 this weekend and I want to clear up a few things real quick. Here is a pic to make this a little easier
Blue: from alt
Yellow: to fuse box
Red: from + battery
Do I need to replace all these wires? That will be alt to positive, I know where the negative ground is at. And where is the chasis to engine wire at? If anyone could help me out thanks!
drowndindreams
Unknown
you dont have to replace them, i just added onto it with 4gauge wiring.
chassis to engine block , which is the last one you listed, you should follow your existing positive wiring, one will lead somewhere under the alternator. wherever that leads, thats where you should run a wire to the chassis.
xX Mavr1ck Xx
xX Mavr1ck Xx
Middle Tennessee
Cool cool. Thanks a bunch drowndindreams, youve been a lot of help. Would had this done tonight, but had to help my friend build his sub box.
drowndindreams
Unknown
oh, and make sure you wear gloves, because it took me 4 days to get the grease off my hands lol.
no problem
AtomicHoe094
Atomichoe094
cleveland, OH
for the +from the battery to the alternator, youll need a inline fuse. the factory comes with a fusible link, so youll have to put one in also with the new wire
Durobans
